LOXJIE A30 Class D Amplifier Infineon MA12070 Bluetooth 5.0 2x50W 4 Ohm
With the A30, Loxjie offers an excellent Class D amplifier that is powerful, compact and affordable. It features excellent components for great sound reproduction and full connectivity for easy integration into the vast majority of audio systems.
4.8 / 5
Reference : 14817
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 17-04-2025.
Loxjie A30
Loxjie A30 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x80W 4 Ohm
Infineon Merus MA12070 amplifier
The amplification circuit is based on an Infineon Merus MA12070 chip. This allows to develop a consequent power of 2x50W under 4Ω, while ensuring a very low distortion, an excellent efficiency and a complete protection system.
The chip's power management algorithm automatically adjusts switching frequency and modulation to limit power loss and EMI interference.
Subwoofer output
The A30 has a suwboofer output on RCA connector. It is thus possible to use the amplifier to power a 2.1 system and enjoy a rich reproduction with deep bass.
Bluetooth
Convenient, the Loxjie A30 allows you to receive your audio files remotely, in Bluetooth, directly from your smartphone. The Bluetooth 5.0 standard combined with the aptX protocol allows for a stable and high quality transmission.
EQ Mode
To suit your listening style and your audio system, the A30 offers no less than 7 preset equalizers as well as a customizable equalizer. The bass and treble levels can be adjusted in 1dB steps from -10dB to +10dB.
Complete connection system
The A30 has full connectivity to integrate with the vast majority of audio systems. The A30 has stereo RCA, Coaxial, Optical and Micro USB inputs. This last input supports sample rates up to PCM 32bit 384kHz. On the output side, there are speaker terminals on the back and a 6.35mm headphone output on the front.
Coaxial input and RCA input share the same interface and therefore cannot be used at the same time.
Quality components
The entire Loxjie A30 benefits from a careful design, based on components known for their audio quality. While the A30 features the very good Infineon MA12070 amplifier chip, the A30 also includes a 24-bit ESS ES9023 DAC with an integrated 2Vrms AOP. The latter uses HyperStream architecture and Time Domain Jitter Eliminator technology to significantly reduce jitter and provide a dynamic range of 112dB.
Volume and tone control is entrusted to an NJW1194 chip, ensuring low distortion and low noise with a ladder resistor system.
Robust and elegant
The components of the A30 are housed in an elegant and robust aluminum case, offering excellent rigidity that also eliminates case vibration, while limiting the impact of electromagnetic interference on the circuits. The screen is protected by a highly transparent tempered glass pane.
Diagram
1Screen
2Jack 6.35mm Headphone output
3Volume / Power button
4Coaxial / RCA right channel input
5RCA left channel input
6Bluetooth antenna
7Optical input
8Subwoofer output
9Micro USB input
10Speaker terminals
11Power connector 24VDC
Test du Loxjie A30 par Audio Science Review
" The Loxjie A30 is an attractive, solid performance with excellent measured and subjective sound quality. Inclusion of a USB DAC and Coax/Toslink input eliminates the need for a DAC for less clutter "
Product typeAmplifier
Amplifier typeClass D
Inputs1x Micro USB
1x Coaxial
1x Stereo RCA
1x Optical
Bluetooth 5.0
OutputsSpeaker terminals
1x Subwoofer output
1x Jack 6.35mm headphone output
Amplification chipInfineon Merus MA12070
DAC chipESS ES9023
Volume control chipNJW1194
THD+N (A-Weighted)0.003%
SNR (A-Weighted)108dB
Power2x 50W @ 4Ω
Headphone output power100mW @ 32Ω
Housing materialAluminum
Consumption35W
Dimensions151 x 170 x 38mm
Weight520g
ColorGrey
Package1x Loxjie A30
1x Remote control
1x Bluetooth antenna
1x USB cable
1x Power supply (24V / 6.75A)
THD+N / Output power (4Ω)
THD+N / Output power (8Ω)
Frequency response
OutputSubwoofer
OutputJack 6.35mm
OutputScrew terminals
ColorGray
Channel2 (Stereo)
Channel2.1
Amplifier chipInfineon MA12070
Power (W)50.0
Remote ControlYes
16 reviews
A great amp, unbeatable for the price
Extremely clean, crisp and analytical sound. No discernible noise, even if you hold your ear directly to the tweeter. This also speaks in favour of the high quality of the power supply unit. Its treble is a little too strong for me personally, but I easily reduced it using the tone control. Operation is very simple and the workmanship is very high quality. Thank you, Audiophonics, for the fast and safe delivery.
This review has been posted for LOXJIE A30 Class D Amplifier Infineon MA12070 Bluetooth 5.0 2x50W 4 Ohm
Précis & Musical
Fonctionne très facilement en Bluetooth (mais juste en 48 kHz...) en délivrant une puissance modeste mais plutôt correcte pour 20-25 M2.
Ne chauffe pas du tout et sans aucun bruit parasite.
Pas encore testé en Hi-Res, via USB ou fibre Optique mais déjà étonnée par la qualité musicale restituée.
Very diverse and good looking
It's a very handsome and diverse device and above all very good sounding.
Loxjie A30
Ordered this little unit because I needed a new amplifier for speaker measurements. The ASR review showed perfect load independent linearity, and that was exactly what I needed for the purpose. In short, it all works as expected, the connections give me all the possibilities to input the measurement signals. And by the way, a short sound test via spdif convinced me so far. For a second sound system, or perhaps as a travel companion, the device is a great option. Small criticism: The device tilts a bit, because one foot is sunk deeper than the others. Since this is easy to fix and does not affect the function, I still give all stars as a rating.
Excellent !
Vraiment ravi de mon ampli. J'avais, juste avant un FX-AUDIO, (D802C) qui faisait le taf musicalement mais qui avait deux soucis, la connectique : pas de sortie Subwoofer et l'écran qui a mal vieilli et qui était illisible, à part dans le noir total... Pour mon caisson je le branchait donc en parallèle sur mes enceintes mais bon...
Là on a produit vraiment au top, je le préfère 100 fois ! Déjà la finition, l'écran magnifique à côté de mon D802C. Couleurs personnalisable, dimmer automatique ou non, sortie Sub, et SURTOUT plus progessif niveau volume. Dans mon cas je suis branché en USB sur mon PC (donc en système 2.1 caisson Magnat et enceintes maison) Avec le FX-AUDIO, avant, même volume à 1 c'était trop fort une fois tout le monde couché, mon PC étant sur le palier devant les chambres... C'était tout ou rien, à moins de me brancher en analogique mais cela n'aurait aucun intérêt. Là je trouve un volume progressif parfait sur ce LOXJIE. Franchement, pour 30€ c'est le jour et la nuit.
 (3)
With the A30, Loxjie offers an excellent Class D amplifier that is powerful, compact and affordable. It features excellent components for great...
