By buying this product you get 247 loyalty points
Streamer BluOS Amplifier nCore WiFi Bluetooth ES9028 2x100W 4 Ohm
Succeeding the excellent multi-awarded NAD M10 connected amplifier, the M10 V2 takes its technical base while bringing several improvements and features. We therefore find a streamer and amplifier particularly powerful and versatile, with extended connectivity thanks to WiFi and bidirectional Bluetooth, but also with a wide range of connectors including subwoofer outputs and an eARC HDMI port.
The amplifier stage of the NAD M10 V2 embeds an nCore HybridDigtal module, capable of delivering a power of 2x100W under 4 and 8Ω with a high efficiency. A power that allows it to be integrated even within demanding audio systems, but also a controlled power for a precise, dynamic and incredibly lively sound reproduction.
In addition, the M10 V2 includes a Dirac Live Room DSP for effective acoustic correction to optimize the sound of the device for the speakers and your listening room. The use of a calibration microphone (not supplied) allows to establish an optimized profile in an automatic and easy way.
The digital-to-analog conversion section uses a Sabre ESS ES9028 chip, capable of high quality decoding for clear and detailed sound reproduction. It also supports high-resolution audio streams up to PCM 32bit 384kHz.
The NAD M10 V2 is powered by an ARM Cortex A9 1GHz processor and the BluOS operating system. The latter, through an ergonomic and attractive interface, ensures an intuitive use. It allows you to access your music and set up your device easily and quickly.
The M10 V2 is also remotely controllable with the free BluOS Controller mobile app available on Android and iOS. It allows you to manage your music playback, access your network storage and even offers the possibility of multi-room management, BlueSound compatible.
The NAD M10 V2 is also controllable with the voice assistants Amazon Alexa and Apple Siri. You just need to have a smart system (not included) of this type to take control of your music by voice.
The rear panel of the NAD M10 V2 reveals a complete connectivity, allowing it to be integrated into most audio systems. It offers stereo RCA, coaxial, optical, USB-A (USB Host for storage devices), an Ethernet RJ45 port and an HDMI eARC input. For the outputs, the M10 V2 offers HP terminals but also a pre-out on stereo RCA as well as two subwoofers outputs.
1 | 12V Trigger input |
2 | 12V Trigger output |
3 | Stereo RCA input |
4 | Stereo RCA input |
5 | Stereo RCA pre-out |
6 | Subwoofer outputs |
7 | Coaxial input |
8 | Optical Toslink input |
9 | HDMI eARC input |
10 | USB-A input (USB Host) |
11 | Ethernet RJ45 input |
12 | Service port |
13 | Standby button |
14 | Power connector |
15 | Right channel speaker output |
16 | Left channel speaker output |
The robust chassis of the M10 V2 features a large and beautiful color touchscreen on the front, which is automatically activated by a proximity sensor when the hand is approached. This, in combination with the BluOS software interface, allows a fluid and intuitive navigation for an optimal user experience.
Product type | Streamer Amplifier |
Inputs | Bluetooth WiFi 2* Stereo RCA 1* Coaxial 1* Optical Toslink 1* HDMI ARC 1* USB-A (USB Host) 1* Ethernet RJ45 |
Outputs | Bluetooth WiFi 1* Stereo RCA pre-out 2* RCA subwoofer outputs Speaker terminals |
Connectivity | WiFi 5 Two-way Bluetooth Ethernet Gigabit RJ45 |
Other connectors | 12V Trigger in/out |
DAC chip | ESS Sabre ES9028 |
OS | BluOS |
Supported audio formats | MP3, AAC, WMA, OGG, WMA-L, ALAC, OPUS |
Supported high resolution audio formats | MQA, FLAC, WAV, AIFF, DSD |
Supported sampling rates | PCM up to 32bit 192kHz |
Supoprted straming services and webradios | Spotify Deezer Qobuz Tidal Amazon Music Napster HDTracks HighResAudio Murfie Juke Slacker Radio KKBox Bugs TuneIn Radio iHeartRadio Calm Radio Radio Paradise |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX HD |
Dolby Digital compatibility | Up to 4.2 channels |
Output power | > 100W (ref. 20Hz-20kHz @ rated THD, two channels) |
THD | < 0.03% (250mW to 100W, 8Ω and 4Ω) |
SNR | > 85.1dB (A-Weighted, 500mV input, ref. output 1W @ 8Ω) |
Clipping power | > 130W à 1kHz, 8Ω, 0.1% THD > 230W @ 1kHz, 4Ω, 0.1% THD) |
IHF Dynamic power | 8Ω: 160W 4Ω: 300W |
Damping factor | > 190 (ref. 8Ω, 20Hz-20kHz) |
Frequency response | ±0.6dB (20Hz-20kHz) |
Tone control | Treble: ±6.0dB @ 20kHz Bass: ±6.0dB @ 60Hz |
Channel separation | > 83dB (1kHz) 70.5dB (10kHz) |
Input sensitivity (@ 100W, 8Ω) | Line in: 456mV Digital in: -13.23%Fs |
Supply voltage | 100-240VAC 50/60Hz |
Dimensions (L*P*H) | 245*260*100mm |
Color | Black |
Input | HDMI |
Input | RCA |
Input | Optical |
Input | RJ45 |
Input | WiFi |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Output | RCA |
Output | Subwoofer |
Output | WiFi |
Output | Speaker terminal |
Output | Bluetooth |
DAC / ADC Chip | ES9028Q2M |
Max sampling rate | 192kHz |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Hypex Ncore |
Power (W) | 100.0 |
Remote Control | Yes |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
