O-NOORUS PA-316 Amplifier Class D 2x TPA3116D2 Bluetooth 5.0 2x60W 4 Ohm
This small, compact, versatile and high-performance O-Noorus PA-316 Class D amplifier incorporates two TI TPA3116D2 amplifier chips, each dedicated to one channel. It is thus capable of delivering a comfortable 2x60W at 4Ω (1% THD).
4.0 / 5
Reference : 18201
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 17-09-2026.
O-Noorus PA-316
O-Noorus PA-316 Amplificateur Class D 2x TPA3116D2 Bluetooth 5.0 2x60W 4 Ohm
This small, compact, versatile and high-performance O-Noorus PA-316 Class D amplifier incorporates two TI TPA3116D2 amplifier chips, each dedicated to one channel. It is thus capable of delivering a comfortable 2x60W at 4Ω (1% THD). In addition to a stereo RCA input and a USB-A port, it features a Bluetooth 5.0 receiver for wireless music streaming from a smartphone or tablet, for example. It is also equipped with a subwoofer output (RCA), offering the possibility of integrating a true 2.1 audio system. The front panel also features a volume knob associated with an NJW1194 chip, plus ±10dB bass and treble adjustment. All components are housed in a sturdy, sober CNC-machined aluminum case.
1Active input indicator
2Bass setting
3Enable/Disable tone control
4Treble setting
5Volume setting
6Bluetooth antenna
7USB-A input
8RCA input
9Subwoofer output
10Speaker output
11Power input
Product typeAmplifier
Amplification typeClass D
Amplification chips2* TPA3116D2
InputsBluetooth 5.0
1* USB-A
1* Stereo RCA
OutputsSpeaker terminals
Subwoofer outputRCA)
Output powerMax : 2*100W @ 4Ω, 1% THD, 24V
RMS : 2x60W @ 4Ω, 1% THD, 24V
Supply voltage24VDC 6.5A (power supply included)
Dimensions133*138*40mm
Weight680g
Housing materialAluminum
Package1* O-Noorus PA-316
1* Power supply
1* Antenna
1* USB-A cable
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
Channel2.1
Amplifier chipTPA3116D2
Power (W)60.0
Not perfect but good for the low price
My pa-316 just arrived
long press volume to turn it on,off short input selection (no aut bt) no pop sound turning it on,off
loose volume knob, like a steering wheel that only make the car turn after half an inch (hate it)
tone controls off neutral sound, clean sound even at max volume, above 12 o'clcok if you want it loud (volume better on a Fosi audio bt 20a), the difference on the volume from 12 o'clock to max is to big or not big enough how you interprest it (medium to loud from 12 to 2 o'clock) + a good bass
Gets varm playing loud (not alarming), a Fosi Audi bt20a don't get warm, 24v 6.75 psu instead of 24volt 4.5 a as some amps has
Usb works but no driver to change samplerate and to se what samplerate is used
This review has been posted for O-NOORUS PA-316 Amplifier Class D 2x TPA3116D2 Bluetooth 5.0 2x60W 4 Ohm
This small, compact, versatile and high-performance O-Noorus PA-316 Class D amplifier incorporates two TI TPA3116D2 amplifier chips, each dedicated...
