By buying this product you get 20 loyalty points
Multiroom Amplifier WiFi 2x20W + Bookshelf Speaker Ribbon Tweeter+ Speaker Cable Copper / Silver
This ready-to-use package contains a Dayton Audio WF40A amplifier, a pair of Dayton Audio B652 speakers and a 4m Media-Sun MS2S speaker cable. An ideal pack to enjoy a system that is powerful, affordable, has many useful features and above all complete and therefore completely ready for use. All you have to do is plug in and enjoy your favourite songs.
This small amplifier from Dayton Audio has WiFi connectivity and is extremely easy to set up. But more than its ease of use, the device also offers practical features such as multiroom, multi-channel and multi-user..:
Multiroom : The amp allows you to play your audio files synchronously in different rooms of your home, for smooth and transparent listening.
Multi-channels : It is also possible to listen to different music in each room by combining music with a defined device.
Multi-users : Finally, it also allows multiple users to control it to play multiple tracks in different rooms.
The iEast mobile application allow you to control compatible devices, such as this WF40A, remotely over WiFi to enjoy the multi-room experience. So, this application allows you to stream your favorite music services, enjoy your music directly stored on your device or fetch files available on your computer or on a USB stick connected to the amplifier.
The configuration of the application is also very simple, since you just have to download it on the Play Store for Android or on the App Store for iOS then let yourself be guided by the instructions on the screen.
If the device is connected in Ethernet then it is not necessary to perform the configuration steps.
The WF40A also comes with an infrared remote control to control it directly from your sofa.
These 2-way speakers feature amazing dynamics, deep bass and surprising accuracy at the top of the spectrum thanks to a ribbon tweeter with foolproof efficiency. The 16.5cm diameter bass-midrange speaker allows a sound normally reserved for speakers of a larger size.
This Media-Sun Silhouette MS2S speaker cable provides very good electrical and mechanical properties. Made of 625 silver plated OFC copper wires per conductor, this one offers unequalled conductivity. It will therefore fit perfectly with the WF40A amplifier and the B652 speakers to ensure the cleanest reproduction.
Dayton Audio WF40A | |
Output power | 2x20W RMS / 2x40W Max 8 Ohm |
Compatibility | Mac OS, iOS, Android, Windows |
Supported protocols | DLNA Airplay |
WiFi | 801.11 b/g/n |
Frequency response | 20Hz - 22kHz |
SNR | < 94.5dB |
THD | 0.0005% |
Crosstalk | < 94.1dB |
Supported file formats | 3AMP3, WMA, AAC, AAC+, Apple Lossless, FLAC, APE, WAV |
Supported radio formats | Streaming MP3, CMA, AAC |
Dayton Audio B562 | |
Power | 40W RMS |
Impedance | 6 Ohm |
Frequency response | 70Hz - 25kHz |
Sensitivity | 87dB |
Dimensions | 300 x 180 x 163mm |
Weight | 11kg |
Packaging | Sold by the pair |
Media-Sun MS2S | |
Length | 4m |
Conductors material | Copper |
Conductors plating | Silver |
Section | 2x2.5mm² |
Section per strand | 0.004mm² (0.07mm diameter) |
Cable thickness | 7x3mm |
Sheath color | Transparent |
Fabrication | Germany |
Input | Jack 6.35mm |
Input | RJ45 |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Power (W) | 20.0 |
