SABAJ A10A Amplifier Class D Infineon MA12070 2x80W 4 Ohm
Sabaj unveils its A10a, a powerful and affordable Class D amplifier, based on the use of an Infineon MA12070 amplifier chip. It is thus able to deliver a power of 2x80W under 4 Ohm with a high efficiency, while ensuring a great precision and sound transparency. The whole device benefits from a careful design, using proven and recognized audio components.
Reference : 15664
149,00 €tax incl.
124,17 € tax excl.
Sabaj A10a
Sabaj A10a Amplificateur Class D Infineon MA12070 Symétrique 2x80W 4 Ohm
Sabaj A10a Amplificateur Class D Infineon MA12070 2x80W 4 Ohm
MA12070 Amplification chip
At the heart of the Sabaj A10a is a high output Infineon MERUS MA12070 Class D amplifier chip. This efficient amplifier allows the A10a to develop a power of 2x80W under 4Ω or 2x50W under 8Ω. This chip also offers a wide dynamic range, low distortion and low noise for a clear and precise reproduction.
A controlled power supply stage
Sabaj has done a lot of work on the A10a's power supply stage to provide a clean and stable electrical signal to all the audio circuits. This switching power supply incorporates a large low-loss transformer and is capable of delivering an instantaneous power of 300W, promoting a wide dynamic range while reducing electromagnetic interference.
Subwoofer output
The A10a incorporates a low-pass filter capable of filtering out vocals to promote deep bass. This allows the A10a's subwoofer input to be connected to create a true 2.1 audio system.
Sabaj A10a amplificateur class D Infineon MA12070 2x80W 4 Ohm
A sound that adapts to your desires
Sabaj has integrated in its A10a seven predefined equalizers to adapt the sound of the amplifier to your listening, your music and your equipment. In addition, there is a custom mode, allowing you to adjust the bass and treble levels yourself over a range of +9dB to -9dB.
Sabaj A20a Amplificateur Class D 2x Infineon MA12070 Symétrique 2x90W 4 Ohm Sabaj A20a Amplificateur Class D 2x Infineon MA12070 Symétrique 2x90W 4 Ohm
Product typeAmplifier
Amplification typeClass D
Amplification chipInfineon MA12070
Input1x Stereo RCA
OutputsSpeaker terminals
1x Subwoofer output
Volume controllerNJW1194
Output power2x 80W @ 4Ω
2x 50W @ 8Ω
THD+N0.0045%
SNR98dB
Channels separation89dB
Input sensitivity350mV
Input impedance47kΩ
Supply voltage100-240VAC
Consumption40W
Standby consumption< 0.6W
Dimensions100 x 170 x 63mm
Weight770kg
Package1x Sabaj A10a
1x Power cable
1x Remote control
Sabaj A10a Amplificateur Class D Infineon MA12070 2x80W 4 Ohm Sabaj A10a Amplificateur Class D Infineon MA12070 2x80W 4 Ohm
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)80.0
Remote ControlYes
Sabaj unveils its A10a, a powerful and affordable Class D amplifier, based on the use of an Infineon MA12070 amplifier chip. It is thus able to...
