SILKLINE LITY I Integrated Amplifier Class AB 2x115W 4 Ohm
With its Lity I, Silkline unveils an integrated amplifier capable of delivering 115W @ 4Ω and 75W @ 8Ω. This makes it ideal for medium to large rooms. This class A/B transistor amplifier will integrate easily into your Hi-Fi system. It is capable of driving a wide choice of passive speakers and delivers a truly transparent, soft and warm sound.
4.0 / 5
By buying this product you get 39 loyalty points
Reference : 17839
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 22-04-2025.
SILKLINE LITY I
Integrated Amplifier Class A/B 2x115W 4 Ohm
SILKLINE LITY I Amplificateur Intégré Class A/B 2x115W 4 Ohm
With its Lity I, Silkline unveils an integrated amplifier capable of delivering 115W under 4Ω and 75W under 8Ω. This makes it ideal for medium to large rooms. This class A/B transistor amplifier will integrate easily into your Hi-Fi system. It is capable of driving a wide choice of passive speakers and delivers a truly transparent, soft and warm sound.
High-fidelity design and dual mono architecture
The Lity I is designed to be totally balanced, with both channels powered independently to avoid crosstalk. The channels' respective circuits are both placed towards the sides, followed by internal heat sinks to ensure heat dissipation and isolation of the channels from the toroidal transformer. The amplification components are Toshiba transistors.
A high-quality power stage
The Lity I amplifier incorporates an impressive pure copper toroidal transformer and Rubycon 50V 1000µF filter capacitors to greatly limit interference. What's more, the device offers overvoltage and overcurrent protection to safeguard your system.
Quality connectors
The RCA inputs are 24k gold-plated for fast signal transmission and corrosion resistance. In addition, they are all switched with fully sealed silver contact relays to ensure reliable signal input and low distortion. The speaker terminals are made of gold-plated pure copper for maximum conductivity and anti-oxidation protection.
High-precision volume control
Silkline has equipped its Lity I with a CS3310 volume controller featuring 0.5dB presicion. Its distortion rate is also very low, bringing the Lity I to a total harmonic distortion rate of less than or equal to 0.005% (@1W).
A VFD screen and a clean housing design
Silkline's Lity I features a bright VFD screen for clear information display. Its CNC-machined aluminum alloy casing is clean and simple, with a symmetrically arranged heat dissipation system for aesthetic appeal. The front panel incorporates 6 control buttons to make operation of the Lity I simple and efficient. An IR remote control also enables the amplifier to be operated remotely.
Silkline Lity I rear panel
1Speaker terminal right channel
2RCA inputs
3Speaker terminal left channel
4Power input - ON/OFFswitch
Product typeIntegrated amplifier
Inputs4* RCA stereo
OuputsSpeaker terminal
Input sensibility250mV
Maximum input level3800mV
Output power2x 115W @ 4Ω (@ THD+N 0.1%)
2x 75W @ 8Ω  (@ THD+N 0.1%)
2x 130W @ 4Ω (@ THD+N 10%)
2x 90W @ 8Ω  (@ THD+N 10%)
Frequency response10Hz-100KHz ±1dB
Total harmonic distorsion ≤ 0.005% (@1W)
SNR> 93dB
Channel separation> 91dB
Wave distorsion< 0.001% (1KHz @ 1W)
Phase distorsion< 0.01° (20hz-20Khz)
Volume controlCS3310 (0.5dB steps)
Remote control
Power supplyAC 220 50Hz (250V Fuse)
Standbye power consumption< 1W (EU CE standard)
Dimensions (W*H*D)430*60*240 mm
Weight8kg
Package1* Silkline Lity I
1* Remote control
1* Power cable
OutputSpeaker terminal
ChannelDual Mono
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)115.0
Remote ControlYes
Hautement musical si…
Très bon montage et de qualité de réalisation.
Là où il pêche est par son coffret de tôles fines et vibrantes !
Pas bon du tout, cela a réellement une influence sur le son. Bilan, on démonte et on place des absorbeurs là où il faut. Dedans et dessus.
Une fois fait, ça sonne mate quand on tape dessus, le transfo ne balance plus ses vibrations partout. Et là, enfin, on peut apprécier toutes les qualités de cet excellent ampli à base de transistors bipolaires.
Rodage obligatoire d'une vingtaine d'heures pour l'entendre aussi chanter pleinement.
Bref, les Classe D ne sont pas pour moi, je reste fidèle à la classe A ou AB et ici, vu le prix, cet achat est une belle découverte.
This review has been posted for SILKLINE LITY I Integrated Amplifier Class AB 2x115W 4 Ohm
With its Lity I, Silkline unveils an integrated amplifier capable of delivering 115W @ 4Ω and 75W @ 8Ω. This makes it ideal for...
