SMSL A200 Class D Amplifier
The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x 70W @ 4 ohm. Versatile and compact, the A200 features extensive connectivity.
By buying this product you get 25 loyalty points
Reference : 19295
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 18-04-2025.
SMSL A200 Class D Amplifier Infineon USB HDMI ARC Bluetooth 5.0 2x70W 4 ohm
SMSL A200 picture
The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x70W under 4 ohm. Versatile and compact, the A200 features extensive connectivity with analog RCA input, optical Toslink input and coaxial input, as well as USB-C and an HDMI ARC port. A Bluetooth 5.0 chip also enables wireless reception. Output is via speaker terminals. On the front panel, there are two rounded VUmeters and a display for an aesthetically pleasing user experience. Bass and treble can be adjusted, in addition to the volume control.
SMSL A200: two Infineon MA12070 amplifier chips
SMSL has chosen to integrate two Infineon MA12070 Class D amplifier chips, giving the A200 an output power of up to 2x70W at 4 ohms.
Photo of Infineon amplification chips
Bluetooth 5.0
SMSL A200: Bluetooth 5.0
A Bluetooth 5.0 chip enables the SMSL A200 to benefit from wireless reception. So, for example, you can send your music directly from your smartphone.
SMSL A200: HDMI ARC port
An HDMI ARC port enables the A200 amplifier to retrieve the signal from a TV set for an immersive TV experience using your Hi-Fi speakers.
SMSL A200 HDMI ARC port
A200 amplifier: extensive connectivity
SMSL A200 connectors diagram
1Right channel Vumeter
2Left channel Vumeter
3Display
4Multifunction button
5SPDIF coaxial input
6Bluetooth antenna connector
7Stereo RCA input
8Toslink optical input
9HDMI ARC input
10Entrée USB-C
11Right channel speaker terminal
12Left channel speaker terminal
13Power switch
14IEC power supply
Product typeIntegrated amplifier
Amplification typeClass D
Amplification chip2x Infineon MA12070
Inputs1x Stereo RCA
1x Optical Toslink
1x SPDIF Coaxial
1x USB-C
1x HDMI ARC
Bluetooth
SortieSpeaker terminals
Output power2x 70W @ 4 Ohm
THD+N0.013%
Channel separation-94dB (1kHz)
INput sensitivity-10dB
SNR102dB
Tone adjustmentBass: -5dB/+5dB
Treble: -5dB/+5dB
Power consumption36W
Standby : <0.5W
Dimensions180x47x171mm
Weight1.07kg
Package1x SMSL A200 amplifier
1x Remote control (AAA battery no included)
1x Bluetooth antenna
1x Power supply cable
InputHDMI ARC
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)70.0
Remote ControlYes
Attention à la description qui est erronée sur la sortie Sub.
Pas de sortie Sub sur ce modèle. Je me permet de le rajouter en commentaire pour les potentiels acheteurs, mon mail à audiophonics pour corriger l'erreur étant resté à ce jour sans effet.
Cette erreur provient de la fiche fabricant. nous prenons contact avec lui et corrigeons au plus vite.
This review has been posted for SMSL A200 Class D Amplifier Infineon USB HDMI ARC Bluetooth 5.0 2x70W 4 ohm
The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x 70W @ 4 ohm....
