SMSL A50 Amplifier Class D 2x TPA3116 Bluetooth 5.0 2x60W 4 Ohm
This small SMSL A50 amplifier offers a great power reserve for a dynamic and detailed sound reproduction. Versatile, it adapts to your listening and your audio system thanks to a tone control and a series of predefined equalizers. It also features convenient Bluetooth 5.0 connectivity, allowing you to stream your music remotely from a smartphone or tablet.
Reference : 17649
75,00 €tax incl.
62,50 € tax excl.
This product has been replaced by the SMSL A50 Pro.
SMSL A50
Amplifier Class D 2x TPA3116 Bluetooth 5.0 2x60W 4Ω
SMSL A50 Amplificateur Class D 2x TPA3116 Bluetooth 5.0 2x60W 4Ω
2* TPA3116 amplification chips
With its Class D architecture based on a pair of Texas Instruments TPA3116 amplifier chips, the SMSL A50 is capable of delivering 2x60W of power at 4Ω (1% THD+N) or 2x33W at 8Ω (1% THD+N), with a high efficiency typical of this type of design. Its advanced oscillator and PLL circuitry ensures low jitter while significantly reducing interference. The amplifier is thus able to provide accurate, detailed and transparent sound reproduction.
Multiple EQ & Tone Control
The SMSL A50 offers several predefined EQ to adapt its playback to your music, your listening preferences and your audio system. A tone control also allows you to manually adjust the bass and treble levels over a range of 14dB.
  • E0 : Direct
  • Et : Tone
  • E1 : Bass
  • E2 : Super Bass
  • E3 : Rock
  • E4 : Soft
  • E5 : Clear
Bluetooth 5.0
The SMSL A50's Bluetooth 5.0 wireless connectivity allows you to easily stream and control your music remotely, from a smartphone or tablet for example. The amplifier has a function that allows it to automatically connect to the device to which it has been paired when it is turned on.
IR Remote control
The SMSL A50 comes with an IR remote control you can use to control the amplifier from your sofa. It allows you to adjust the volume level, access the tone control and equalizers or select a source.
Product typeAmplifier
Amplification typeClass D
Amplification chips2* TPA3116
InputsBluetooth 5.0
1* Stereo RCA
OutputSpeaker terminals
Output power2* 33W @ 8Ω, 24V, 1% THD+N
2* 60W @ 4Ω, 24V, 1% THD+N
Frequency response20Hz-20kHz
Bass/Treble control±14dB
THD+N0.02%
Channel separation-105dB (1kHz)
Input sensitivity440mVrms
SNR100dB
Supply voltage range12-24VDC
Consumption36W
Standby consumption< 0.5W
Dimensions (W*D*H)97*107*32mm
Wight300g
Package1* SMSL A50
1* Remote control
1* Power supply
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)60.0
Remote ControlYes
This small SMSL A50 amplifier offers a great power reserve for a dynamic and detailed sound reproduction. Versatile, it adapts to your listening...
