SMSL A50 PRO Amplifier
The SMSL A50 PRO is a 2.1-channel Class D amplifier featuring two Infineon MA12070P amplifier chips. It is capable of developing power up to 2x 70W 4 Ohm + 100W 2 ohm. One of the major advantages of the A50 PRO is its extensive digital connectivity.
Reference : 19185
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 17-04-2025.
SMSL A50 PRO Amplificateur 2.1 Class D 2x MA12070P Bluetooth 5.0 HDMI ARC 2x70W + 100W 2 Ohm
SMSL A50 PRO picture
The SMSL A50 PRO is a 2.1-channel Class D amplifier featuring two Infineon MA12070P amplifier chips. It is capable of developing power up to 2x70W 4 Ohm + 100W 2 ohm. One of the major advantages of the A50 PRO is its extensive digital connectivity. In addition to its USB-C input, it features HDMI ARC, Toslink optical and AUX jack 3.5mm inputs. SMSL has thus made its A50 PRO amplifier compatible with numerous digital devices such as televisions, computers and video game consoles. To top it all off, Bluetooth 5.0 as well as several equalization settings and high/low pass filters are available. Versatile and high-performance, this little amplifier is sure to delight a wide range of users.
SMSL A50 PRO highlights
SMSL A50 PRO: two Infineon MA12070P chips
Inside the A50 PRO you'll find no less than two Infineon MA12070P Class D amplification chips. These chips feature a direct I2S digital input and a very high level of efficiency. They deliver 2x70W at 4 ohms and 100W at 2 ohms to power a passive subwoofer. High dynamic range, low distortion and low noise: these are the characteristics that make them the chip of choice for this SMSL amplifier.
Photo of an INFINEON MA12070P chip
SMSL A50 PRO: 100W subwoofer output
SMSL A50 PRO: 2.1-channel amplifier
As mentioned above, the A50 PRO delivers 100W of power to drive a passive subwoofer with volume control for the most immersive sound reproduction.
SMSL A50 PRO: High/low-pass filter
The A50 PRO features a high-pass filter adjustable from 200Hz to 600Hz and a low-pass filter adjustable from 50Hz to 120Hz by 10 steps each. The subwoofer volume is adjusted separately.
SMSL A50 PRO: adjustable filters
SMSL A50 PRO: numerous digital inputs including HDMI ARC
The A50 PRO incorporates numerous digital inputs: USB-C input, Toslink optical input, 3.5mm AUX input and, above all, an HDMI ARC port. As a result, it is able to receive the audio signal from a TV set, enabling you to enjoy a 2.1-channel home cinema setup.SMSL A50 PRO: high level of compatibility;
SMSL A50 PRO : Bluetooth 5.0
A Bluetooth 5.0 receiver chip lets you enjoy high-definition wireless transmission. So it's easy to pair your phone or tablet to the SMSL A50 PRO.
SMSL A50 PRO Bluetooth function
SMSL A50 PRO presets
SMSL A50 PRO: numerous EQ presets
Up to 6 EQ presets are available, allowing you to adjust the sound reproduction to the musical style being played or to your personal preferences. Treble and bass can be adjusted by 9 levels.
SMSL A50 PRO overview
1Volume control
2Display
3Bluetooth antenna
4USB-C input
5HDMI ARC input
6Toslink optical input
7AUX input 3.5mm jack
8Passive subwoofer output
9Right channel speaker terminal
10Left channel speaker terminal
11DC power supply input (12-24V)
Product typeAmplifier
Amplifier typeClass D
Amplification chipInfineon MA12070P
Inputs1x USB-C
1x HDMI ARC
1x Optical Toslink
1x AUX jack 3.5mm
Bluetooth
OutputsSpeaker terminals
1x Passive subwoofer output
Output power2x 70W @ 4 ohm + 100W @ 2 ohm (subwoofer)
Frequency response20Hz-20KHz
Bass and treble gain-5dB/+5dB
THD+N0.013%
Channel separation-94dB (1KHz)
Input sensitivity-10dB
SNR102 dB
Supply voltage12-24V DC
Energy consumption36W
Standby power consumption<0.5W
Dimensions134 x 33 x 103mm
Weight0.3kg
Package1x SMSL A50 PRO amplifier
1x USB-A to USB-C cable
1x HDMI cable
1x Bluetooth antenna
1x IR remote control
1x Power adapter
InputHDMI ARC
InputJack 3.5mm
OutputSubwoofer
OutputSpeaker terminal
Channel2.1
Amplifier chipInfineon MA12070
Power (W)70.0
Remote ControlYes
2 reviews
Une bonne surprise, avec du souffle
Ma base de comparaison se fait avec Smsl DA-6, Aiyima T9, Xduoo MT-605, Fosi Za3, Aiyima A08 pro, Topping MX3S.
Et des amplis Kenwood vintage qui sont ma préférence jusqu'à aujourd'hui.
Cet ampli sonne brillant, transparent, sans doute la signature des deux MA12070. J'aime bien. Très expressif, peut être trop pour certains. En tonalité direct, les aigus paraissent excessifs, les basses aussi. La rythmique est bien maîtrisée.
Son défaut, c'est que sans musique jouée, il fait du souffle.
Pour le prix, la sonorité, les entrées, la télécommande, la puissance 2X70W présents, je l'ai vraiment apprécié. Et je le préfère en sonorité aux amplis d'Audiophonics, cités plus haut.
This review has been posted for SMSL A50 PRO Amplifier 2.1 Class D 2x MA12070 Bluetooth 5.0 HDMI ARC 2x70W 4 Ohm + 100W 2 Ohm
Good for the price, for 90 euros you can't ask for more. sub output a little weak, I thought the bass would be more present, I used a 4ohm bass unit, I think that with 2ohm subwoofers the bass is stronger.
The SMSL A50 PRO is a 2.1-channel Class D amplifier featuring two Infineon MA12070P amplifier chips. It is capable of developing power up to 2x 70W...
