Class D Amplifier Infineon MA12070 Bluetooth 5.0 2x70W 4 Ohm
The SMSL AO100 is a small, powerful and affordable amplifier, whose careful design allows it to deliver a comfortable power and a precise and dynamic sound reproduction. An ideal ally for those who want to enjoy a HiFi audio system without breaking the bank.
The Infineon MA12070 Class D amplifier chip used in the SMSL AO100 offers a high efficiency of 92% for a reduced power consumption level. The AO100 is thus able to develop a comfortable power of 2x70W under 4Ω, while offering a rich and dynamic sound reproduction.
With the SMSL AO100, no need to move to control the playback of your music. Integrating a Bluetooth 5.0 reception chip, it will allow you to broadcast your music at a distance, directly from your smartphone or tablet.
The AO100 incorporates a high quality switching power supply. This provides a clean and stable electrical signal to the audio circuits.
Another feature of the AO100 is its pre-amplified subwoofer output. This will allow you to use an active subwoofer to create a true 2.1 immersive system.
1 | Display |
2 | IR Receiver |
3 | Multi-function button |
4 | RCA input |
5 | Bluetooth antenna |
6 | Right channel speaker output |
7 | Subwoofer output |
8 | Left channel speaker output |
9 | Power connector |
Product type | Amplifier |
Amplifier type | Class D |
Amplification | Infineon MA12070 |
Output power | 2x70W @ 4Ω |
Inputs | Bluetooth 5.0 1x Stereo RCA |
Outputs | Subwoofer output (RCA) Speaker terminals |
Frequency response | 20Hz-40kHz |
Bass/Treble adjustment | -14dB ~ +14dB |
THD+N | 0.004% |
Channels separation | 109dB (1kHz) |
Input sensitivity | 400mVrms |
SNR | 104dB |
Max input voltage | Low gain: 2Vrms High gain: 1.2Vrms |
Supply voltage | 100-240VAC (Power cable included) |
Consumption | 36W |
Dimensions | 150 x 128 x 39mm |
Weight | 560g |
Color | Black |
Input | RCA |
Input | Bluetooth |
Output | Subwoofer |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Channel | 2.1 |
Class | Class D / T |
Amplifier chip | Infineon MA12070 |
Power (W) | 70.0 |
Remote Control | Yes |
