SMSL DA-8S Amplifier Class D Infineon MA12070 NJW1194 Balanced Bluetooth 5.0 2x80W 4 Ohm
The SMSL DA-8s is a compact and affordable yet high performance symmetrical Class D power amplifier, delivering a comfortable 2x80W power output at 4Ω with a high efficiency of over 92%. These impressive capabilities come from an Infineon MA12070 amplifier module, which provides excellent sound reproduction while limiting power consumption.
Reference : 14585
169,00 €tax incl.
140,83 € tax excl.
SMSL DA-8s
Amplificateur Class D Infineon MA12070 Symétrique Bluetooth 5.0 2x80W 4Ω
SMSL DA-8s Amplificateur Class D Infineon MA12070 Symétrique Bluetooth 5.0 2x80W 4Ω
The SMSL DA-8s is a compact and affordable yet high performance balanced Class D amplifier, delivering a comfortable 2x80W power output at 4Ω with a high efficiency of over 92%. These impressive capabilities come from an Infineon MA12070 amplifier module, which provides excellent sound reproduction while limiting power consumption.
The volume control is entrusted to an NJW1194 chip, allowing precise volume adjustment without adding distortion. The SDB mode of the unit offers the possibility to adjust the bass and treble levels over a range of -10dB to +10dB.
On the connection side, the DA-8s is simple and efficient. The rear panel of the amplifier displays a balanced XLR input and an unbalanced RCA input, as well as speaker output terminals. A small particularity, the SMSL amplifier has Bluetooth 5.0 connectivity supporting the aptX and thus offering the possibility to play music directly from your smartphone or tablet.
The entire DA-8s circuitry benefits from a careful design, incorporating quality components such as Siemens coupling capacitors or Nichicon filter capacitors.
SMSL DA-8s review by Soundnews
If I never knew the price of this unit, I would bet I am listening to an integrated amplifier in the $400 to $600 price range and that says a lot about its performance. At just a fraction of the price, SMSL DA-8S offered a balanced sound across the board. "
Test du SMSL DA-8s par Soundnews
Product typeAmplifier
Amplification chipInfineon MA12070
Amplification typeClass D
Output power2x80W @ 4Ω
2x40W @ 8Ω
Efficiency> 92%
Volume controlNJW1194
InputsBluetooth
1x Single-ended stereo RCA
1x Balanced  stereo XLR
OutputsSpeaker terminals
Housing materialAluminium
ColorSilver
Dimensions185 x 125 x 40mm
Weight1kg
Power supply24VDC (power supply included)
Package1x SMSL DA-8s
1x Power supply
1x Remote control
1x Bluetooth antenna
InputXLR
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)80.0
Remote ControlYes
3 reviews
Bluffe
Ce petit ampli est incroyable... Les classe d m'étaient inconnus il ya encore 3 jours et la je suis juste bluffé.. Je l'ai couple à des cabasse Antigua, et dessus je branche l'ordi en passant par un arcam irdac 2 et une platine vinyl et le son est top vraiment même à haut volume... C'est qd même pas aussi bon que le système de salon. Consonance opéra a tubes, rme adi 2dac et bw 603, mais c'est loin d'être à la traîne... Pour un prix bien plus modique
This review has been posted for SMSL DA-8S Amplifier Class D Infineon MA12070 NJW1194 Balanced Bluetooth 5.0 2x80W 4 Ohm
COUTEAU SUISSE
A l ouverture du colis parfait comme d habitude chez audiophonics (non non je n'ai pas d actions chez eux) on découvre un joli boitier a la finition parfaite . Difficile de demander plus a ce prix .
Qt a l'utilisation chez moi pour un système annexe , ampli intégré pour les prises rca ( tuner) et le bluetooth et ampli de puissance pour les xlr avec un préampli passif . Petit reproche, les prises symétriques ne sont pas verrouillables .
L' écoute s' est pour l instant cantonnée avec mes Gaïa minor et c'est très prometteur . Prochaine étape branchement sur le système principal ,mes baffles plans équipés de PHY 30 SAG .
Solution peu couteuse et performante pour supporter les mois d'été sans avoir a supporter le chauffage des tubes .
Great class D Amp
The unit is small and solid built. I paired it with a set of 2 JBL Control 1. It has no problem powering the speakers and the audio is great. It is a no brainer choise for a compact home theater system. The only drawback for some is the lack of an optical and dedicated subwoofer output. However if you pair it with the right speakers it would be no problem. The Bluetooth audio in, seemed a little muffled but with the right set of tremble it was corrected.
The SMSL DA-8s is a compact and affordable yet high performance symmetrical Class D power amplifier, delivering a comfortable 2x80W power output at...
