SMSL DA-9 Balanced Class D Amplifier 2x MA12070 Bluetooth 5.0 2x90W 4 Ohm
The SMSL DA-9 is a high quality amplifier with a symmetrical architecture that allows it to reveal a rich and precise musical sound reproduction. Using high-end components for excellent performance, the device is also practical with Bluetooth support for remote broadcasting of your music.
4.8 / 5
Reference : 15247
249,00 €tax incl.
207,50 € tax excl.
This product is temporarily unavailable.
SMSL DA-9
Balanced Class D Amplifier 2x Infineon MA12070 Bluetooth 5.0 2x90W 4 Ohm
SMSL DA-9 Amplificateur Class D Symétrique 2x Infineon Bluetooth 5.0 2x90W 4 Ohm
The SMSL DA-9 is a high quality amplifier with a symmetrical architecture that allows it to reveal a rich and precise musical sound reproduction. Using high-end components for excellent performance, the device is also practical with Bluetooth support for remote broadcasting of your music. The DA-9 also features a subwoofer output, allowing for the integration of a 2.1 audio system.
Bluetooth 5.0
The DA-9 incorporates Bluetooth 5.0 transmission technology, allowing you to stream your music simply and remotely directly from your smartphone. In addition, it supports the aptX and UAT transmission codec for a sound quality close to that of CD in Bluetooth.
Predefined equalizers
In order to adapt to each person's listening style, the SMSL DA-9 offers many predefined equalizers.
Optimized circuits
The DA-9 incorporates many high-end components dedicated to audio. These include an NJRC NJW1194 volume control for precise adjustment and low distortion, two high-output Infineon Class D amplifiers, a fully balanced circuit, a power supply optimized for low interference and dynamic range, and dual filtering at the input stage.
1IR Receiver
2Screen
3Volume / Function knob
4Power input
5Right channel output
6Left channel output
7Subwoofer output
8RCA input
9XLR input
To operate the remote control, press the A button on the remote control.
Product typeAmplifier
Amplifier chip2x Infineon MA12070
InputsXLR
RCA
Bluetooth 5.0 (Apt-X / UAT)
OutputsSpeaker terminals
THD+N0.003%
SNR111dB
Channel separation96dB
Input sensitivity / impedance250mV / 47kΩ
Power output2x 150W @ 2Ω
2x 90W @ 4Ω
2x 50W @ 8Ω
Consumption40W
Standby consumption0.5W
Dimensions187.5 x 154 x 40mm
Weight0.96kg
Housing materialAluminum
Package1x DA-9
1x Remote control
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2.1
Amplifier chipInfineon MA12070
Power (W)90.0
Remote ControlYes
5 reviews
Un bon ampli de Classe D
Je possède un D5pro et suis passé sur un AD-9 qui semble "marcher" tout aussi bien. Mes oreilles étant passé en Classe D je n'ai pas trouvé une grande différence. Pas de bruit de fond son bien spatialisé sur Mes colonnes triangle et mon sub-woofer Triangle.
A noter pas d'interrupteur physique, l'ampli se remet en On au retour du courant malgré l’Arrêt via la télécommande avant coupure de l'ensemble hifi (économies de veille oblige). Sinon RAS
This review has been posted for SMSL DA-9 Balanced Class D Amplifier 2x MA12070 Bluetooth 5.0 2x90W 4 Ohm
A true killer amplifier
Amazing amplifier! Better than Sugden A21 SE and 14 times cheaper!!!
Good performance amp
Pleasant surprise the amplifier. It was difficult for me to decide to buy a class D because I always had class AB amplifiers. The vocals are a bit flat but I pass it with its good dynamics. The only problem is that the amplifier refuses to start from the remote control ! That's why 4 stars instead of 5.
Une boule d'énergie
Après de longues heures d'écoute, je peux dire que ce classe D fait aussi bien, sinon mieux dans les micros informations, que mon Mc Intosh MA 6300 (16 fois plus cher). Le smsl tient d'une main de maitre mes cabasse catalane 500. Je plussoie à ce qui a déjà été dit sur l'avenir de la classe D , dans le domaine de l'amplification. Je recommande cet article.
 (4)
Champion
Ce petit ampli est un champion, je n'ai comme comparaison que l' Alientek D8 et le Aiyima 07 avec OPA1612, il les supplante allègrement.
Branché en RCA avec Sanskrit.
Magnifique!!!!
The SMSL DA-9 is a high quality amplifier with a symmetrical architecture that allows it to reveal a rich and precise musical sound reproduction....
