SMSL MINI 5 Amplifier TDA7492 2x 50W / Headphone Amp 130mW 32 Ohm Silver
Reference : 10520
69,00 €tax incl.
57,50 € tax excl.
A digital amplifier architectured around a TDA7492 delivering 2x 50W, the MINI 5 also incorporates a headphone amplifier capable of providing 130mW under 32 Ohms.
It is a compact and robust amplifier with the entire chassis in Aluminum.
The design and finishes are neat (CNC machining), its ergonomics is an indisputable advantage.
Its technical characteristics are a significant advantage compared to the competitors of this range: it is efficient and precise.
Characteristics :
  • Frequency response: 20Hz - 20kHz to +/- 3dB
  • Noise Ratio: 98dB
  • THD: 0.1%
  • Output power: 130mW (under 32 Ohms)
  • Adjusting the volume
  • EMI Filtering
  • Short circuit protection
  • Protection against overheating
  • Input line Jack 3.5mm
  • Headphones Jack 3.5mm
  • Output terminal blocks Hp to screw
  • Chassis Aluminum Anodized Silver
  • Dimensions: 132x73x30mm
  • Weight: 1kg
  • Power supply 19V DC 3A included
[Img-14526-left-thickbox_default]
[Img-10114-left-thickbox_default]
[Img-10115-left-large_default]
ColorSilver
ClassClass A / AB
