The SMSL SA-36A Plus is a remarkably efficient, compact audio amplifier that takes advantage of a wide range of connectors allowing it to be associated with many different sources.
Indeed, this amplifier has a USB input, an SD card input, an AUX jack 3.5mm, and an Wireless Bluetooth 4.1 antenna.
Its amplifier module TPA3118 Class D allows it to deliver an output power of 2x30W under 8 Ohm. It benefits from high quality electronic components.
On its front panel, 5 buttons of commands. A Play / Pause button, the 2 volume buttons +/-, the Power button, as well as the button for the various buttons settings EQ Mode .
Qobuzissime for the SMSL SA-36A Plus
(Review by Qobuz)
" This S.M.S.S.L SA-36A Plus switching amplifier may have amazed us even more than the AD18 and A8 models of the brand by offering, at a lower power level but not negligible, and at a really low price, sound performances that remind us furiously of those of its big brothers. "
![Test Qobuz](https://www.audiophonics.fr/img/cms/Images/Icones/Qobuzissime.png)
General specifications:
- Amplifier chip: TPA3118 / Class D (PDF available in attached files)
- Output power: 2x 30W under 8 Ohm / 2x 50W under 4 Ohm
- Bluetooth version: 4.1
- Maximum sampling rate: 16 Bit / 44kHz
- EQ Fashion: Flat / Rock / Pop / Classical / Jazz
- Power supply in 24V DC
- Power Consumption: 22W
- Power consumption at rest: 0.5W
- Accepts file formatsrs: WMA / MP3
Connectivity / Dimensions / Weight:
- Input USB-A (Up to 64GB) / SD Card In (Up to 32GB)
- Output: HP Stereo Terminal Block
- Input AUX Jack 3.5mm
- Dimensions: 250x188x68mm
- Weight: 322g
- Black color
- Black Face
- Comes with: 24V AC adapter / Bluetooth antenna
![](https://www.audiophonics.fr/31718-thickbox_default/smsl-sa-36a-plus-amplificateur-numerique-tpa3118-bluetooth-41-2x-30w-8-ohm-noir.jpg)
![](https://www.audiophonics.fr/20378-thickbox_default/smsl-sa-36a-plus-amplificateur-numerique-tpa3118-bluetooth-41-2x-30w-8-ohm-noir.jpg)
