By buying this product you get 79 loyalty points
The SVS Prime Wireless Pro SoundBase is a robust 300W stereo amplifier (150W per channel) with a 192 KHz/24-bit DAC housed in a compact and high-tech box. It is able to drive any speaker to its full potential with plenty of dynamics, powerful bass and crystal clear sound. Its internal components are of audiophile quality. This integrated audio amplifier is perfect for people using streaming services. Among other things, it can wirelessly stream high-resolution lossless audio via WiFi, Apple Airplay 2 for iPhone and iOS and Chromecast for Android phones and other devices. The Bluetooth function is also present.
Its other strong point lies in its fairly complete connectivity with an HDMI ARC / eARC input and a subwoofer output for deeper and immersive bass.
With its Class D amplifier of 300W (2x150W) the SVS Prime Wireless Pro SoundBase allows you to broadcast powerful and impactful sound. The sound will remain clear and clean even at high volumes.
Take control of your SVS Prime wireless pro SoundBase remotely in a perfectly intuitive way thanks to its WiFi connectivity. The SVS Prime wireless pro SoundBas has several wireless streaming options:
1 | Speaker terminal |
2 | RCA input |
3 | Jack 3.5mm input (Aux) |
4 | HDMI ARC/eARC input |
5 | USB-A input |
6 | Ethernet RJ45 input/ouput |
7 | Subwoofer output |
8 | RCA output |
9 | Optical Toslink input |
10 | IR 3.5mm input |
11 | WiFi setup |
12 | Bluetooth setup |
13 | Power supply : Automatic switching 100–120V / 220–240V, 50/60 Hz |
The DTS Play-Fi application, available free of charge on Android and iOS, allows you to remotely control your SVS Prime Wireless Pro SoundBase. Thanks to its ergonomic and intuitive interface, simply stream your music from your smartphone. This integrated amplifier also has the option of native control via Apple Airplay 2 for iPhone and iOS, Spotify Connect and Google Chromecast for Android phones and devices.
Alexa, Siri and Google voice control is possible via supported devices as well as use in a multiroom system to enjoy your music throughout your home (DTS Play-Fi compatible products).
Finally, the front panel user interface is quite rich in terms of data display and an IR remote control is provided.
Product type | Integrated amplifier |
Amplification type | Class D |
Inputs | 1x HDMI ARC/eARC 1x IR Jack 3.5mm 1x Jack 3.5mm AUX (input impedance: 20K) 1x Optical Toslink (96kHz) 1x Ethernet RJ45 1x USB-A 1x RCA (input impedance: 20K) Bluetooth (AAC and aptX) WiFi |
Outputs | 1x Speaker terminals 1x Pre-out stereo RCA (2V Max) 1x Subwoofer RCA (2V Max) 1x Jack 3.5mm headphone output (1V @ 32Ω max) 1x RJ45 Ethernet |
Output power | 2x150W RMS @ 4Ω |
Band width | 10Hz-20kHz (±1dB) |
SNR | 100dB @1V, 2x150W |
Screen | OLED 3.15" |
Supported WiFi protocols | AirPlay 2 Spotify Connect Chromecast |
Power supply | Switch mode: Automatic switching 100-120V / 220–240V, 50/60Hz |
Fuse | 6.3A / 250V |
Color | Gray |
Weight | 2.2kg |
Dimensions (W*D*H) | 230.8*223.8*82mm 82mm |
Package | 1x SVS Prime Wireless Pro SoundBase 1x Remote control (batteries included) 1x Power cable |
Input | IR |
Input | USB |
Input | Jack 3.5mm |
Input | Bluetooth |
Input | WiFi |
Input | HDMI ARC |
Input | RCA |
Input | Optical |
Input | RJ45 |
Output | RCA |
Output | Jack 3.5mm |
Output | Subwoofer |
Output | Speaker terminal |
Output | RJ45 |
Color | Gray |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 300.0 |
Remote Control | Yes |
