THINKYA DVR-102 Amplifier / Preamplifier
Thinkya unveils a singular device with its DVR-102, a Class AB integrated amplifier based on the use of ECC83/ECC82 tubes for its preamplification stage and Toshiba PNP A1941 and NPN C5198 transistors for its power stage. One of its key features is that it features RCA input and output jumpers, enabling it to be used as a preamplifier or only as a power amplifier.
By buying this product you get 47 loyalty points
Reference : 19962
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 22-04-2025.
Thinkya DVR-102 Amplifier/Preamplifier Class AB Tubes ECC83/ECC82 Bluetooth 5.0 2x 75W @ 4 ohm
THINKYA DVR102 picture
Thinkya unveils a singular device with its DVR-102, a Class AB integrated amplifier based on the use of ECC83/ECC82 tubes for its preamplification stage and Toshiba PNP A1941 and NPN C5198 transistors for its power stage. One of its key features is that it features RCA input and output jumpers, enabling it to be used as a preamplifier or only as a power amplifier. An NJW1194 digital volume control chip offering 60 steps of adjustment completes the package. In addition, a CS8416 digital interface chip enables it to offer various digital inputs, plus Bluetooth 5.0 functionality. Its speaker terminal output is capable of delivering 2x60W into 4 ohm, enabling it to soundtrack a beautiful space. The Thinkya DVR-102 amplifier is as original in its possible uses as it is in its retro-futuristic aesthetic, and will delight many audiophiles.
Thinkya DVR-102: high-performance amplification
As mentioned above, the Thinkya DVR-102 is based on a set of audiophile components. The masterpieces of its preamplification stage are, of course, the two pairs of PSVANE ECC83 and ECC82 tubes, which add roundness and warmth to the final result. The amplification stage is based on Toshiba A1941 and C5198 transistors capable of delivering up to 2x 60W of power under a 4 ohm load, while maintaining a THD of 0.1%.
Preamplifier tubes
Native tubesCompatible replacement models
ECC8312AX7(B)B759E83CC7729
ECC8212AU7B749E82CC7316
THINKYA DVR102 amplification components
Thinkya DVR-102 : volume control NJW1194
The stereo digital volume control chip features low noise and low distortion thanks to its resistance ladder circuit design. It can therefore control the volume level of the Thinkya DVR-102 over a range of 0 to 60 without damaging the signal. Each adjustment step is equivalent to 0.5dB.
THINKYA DVR102 volume control
THINKYA DVR102 Bluetooth functionality
Thinkya DVR-102: Bluetooth 5.0
A Bluetooth 5.0 receiver chip enables the Thinkya DVR-102 to be used with a smartphone for a reliable, stable wireless connection. This makes it possible, for example, to take advantage of various streaming services installed on the smartphone.
Thinkya DVR-102: CS8416 digital interface
The CS8416 digital interface chip enables the Thinkya DVR-102 to receive sampling rates up to 24bit 192kHz on its Toslink optical and coaxial SPDIF inputs.
THINKYA DVR102 digital inputs
USB-A (Disk) input for THINKYA DVR102
Thinkya DVR-102: USB-A Disk input
The Thinkya's front panel features a USB-A (DISK) input for use with a source such as a USB stick. This input supports file formats such as FLAC, APE, WAV, MP3 and WMA.
Thinkya DVR-102 overview
THINKYA DVR102 overview
1Ignition button
2ECC83/ECC82 tubes
3Display
4USB-A input (DISK)
5Control buttons
6Input selection
7Tone control
8Volume control
9SPDIF Coaxial input
10Bluetooth antenna
11Optical toslink input
12RCA input (CD)
13RCA input (AUX)
14PRE-LINE RCA input/output with jumpers
15Speaker terminal output
16Ventilation system
17AC power input/Fuse
Thinkya DVR-102: separate preamplifier and power amplifier stage
The Thinkya DVR-102's connectors feature a preamplifier output and a power amplifier input, as well as two jumpers. This allows the Thinkya DVR-102 to be used as an integrated amplifier, preamplifier or power amplifier, making it extremely versatile.
Integrated amplifier configuration
configuration
The jumpers in place allow digital and analog inputs to be used for output to the speaker terminals.
Pre-amplifier use
Preamplifier
use
If you remove the jumpers, you can use only the preamplifier stage via the RCA PRE-LINE OUT.
Power amplifier use
Power amplifier
use
If you remove the jumpers, you can use only the power amplifier stage via the PRE-LINE IN input.
Thinkya DVR-102: tone control and RCA CD tone control bypass
The Thinkya DVR-102 offers +/-10dB bass and treble tone control. However, the RCA CD input lets you bypass this tone control for purer rendering and enjoy the best recordings without altering the signal.
Tone control bypass
THINKYA DVR102 remote control
Thinkya DVR-102 : Remote control unit
A remote control offers a very pleasant user experience. It lets you perform all the operations you need to control your Thinkya DVR-102, thanks to an extensive interface of control buttons.
Product typeIntegrated tube amplifier
ClassAB
Tubes2x ECC82
2x ECC83
TransistorsToshiba PNP A1941
Toshiba NPN C5198
Volume controlNJW1194
Digital interfaceCS8416
Inputs1x Coaxial
1x Toslink optical
1x RCA stereo (CD)
1x RCA stereo (AUX)
1x USB-A (U-disk)
Bluetooth
1x RCA PRE-LINE (preamp bypass)
OutputsSpeaker terminals
1x RCA PRE-LINE output (preamp only)
Output power2x60W @ 4 ohm (THD = 0.1%)
2x50W @ 6 ohm (THD = 0.1%)
SNR> 80dB
Input sensitivity350mV (RCA CD-AUX)
750mV (optical Toslink/coaxial)
Supported sample ratesCoaxial and optical Toslink: 24bit 192kHz
Bluetooth range10m
Supported audio formats via U-diskAPE, FLAC, WAV, MP3, WMA
Tone controlBass: +/-10dB
Treble: +/-10dB
Frequency response20Hz-20KHz
Cooling fanInternal temperature measurement circuit for automatic start-up
Power supply220V AV 50Hz
ColorSilver
Dimensions260 x 315 x 150mm
Weight6.65kg
Package1x Thinkya DVR-102 amplifier
1x Remote control
1x Bluetooth antenna
2x RCA Jumpers
1x Screwdriver for remote control
1x Mains cable
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipA1941
Amplifier chipC5198
Power (W)60.0
Remote ControlYes
THINKYA DVR-102 Amplifier Preamplifier Class AB Tubes Hybrid ECC83 ECC82 Bluetooth 5.0 2x75W 4 ohm
Thinkya unveils a singular device with its DVR-102, a Class AB integrated amplifier based on the use of ECC83/ECC82 tubes for its preamplification...
