This product has been replaced by the Tonewinner AD-66D PRO.
Amplificateur 2.1 Class A Toshiba TTC5200/TTA1943 2x135W 4Ω
The Tonewinner AD-66D is an efficient and versatile Class A amplifier with a proven technical foundation for musical and detailed sound. Its circuitry uses audiophile-grade components to ensure excellent performance, including low noise and distortion. It also provides a complete set of connectors to meet the vast majority of needs for home audio integration.
The AD-66D's Class A amplifier stage is based on the use of two pairs of high power Toshiba TTA1943/TTC5200 transistors, allowing to develop 2x80W under 8Ω or 2x135W under 4Ω. The amplifier also benefits from a particularly careful architecture, ensuring a low level of distortion, thus revealing a musical and rich sound. Moreover, the AD-66D provides a subwoofer output allowing the addition of a subwoofer within a 2.1 system. The speaker output is equipped with a protection circuit, effectively securing your equipment.
With its numerous digital inputs, the Tonewinner AD-66D is of course equipped with a digital / analog conversion section. This one embeds an Analog Devices AD1955 DAC chip, decoding PCM audio streams up to 24bit 192kHz and ensuring an SNR as well as a dynamic range of 120dB.
In order to meet the vast majority of needs, the AD-66D offers a full range of connectivity, including input with USB, optical, coaxial, HDMI ARC, a Micro SD port, stereo RCA but also thanks to a Bluetooth 4.2 receiver using an ATS2825 chip. It is thus possible to broadcast and control your music remotely, from a smartphone for example, directly to the amplifier.
1 | Speaker output |
2 | Mini USB input |
3 | Micro SD slot |
4 | Bluetooth antenna |
5 | Optical Toslink input |
6/7/8 | Coaxial inputs |
9 | Subwoofer output |
10 | RCA pre-out |
11 | Amp input |
12/13/14 | Stereo RCA inputs |
15 | HDMI ARC input |
The Tonewinner AD-66D is equipped with a highly accurate JRC NJW1194 stereo volume controller. It allows an efficient adjustment of the sound level, ensuring a low level of noise and distortion. The sound level adjustment is done in 0.5dB steps.
The power supply stage of the Tonewinner AD-66D benefits from the same care given to the audio circuits of the unit. It is equipped with a large custom toroidal transformer and capacitors with a capacity of 15000µF to provide a clean electrical signal at all times.
Product type | Amplifier |
Amplification type | Class A |
Inputs | Bluetooth 1* Mini USB (USB Audio) 1* USB-A (USB Host) 1* Micro SD slot 1* HDMI (ARC) 1* Optical Toslink 3* Coaxial 3* Stereo RCA |
Outputs | Speaker terminals 1* Subwoofer output (stereo RCA) |
Output power | 2*135W 4Ω 2*85W RMS 8Ω (THD 1%, 1kHz) |
Transistors | TTC5200 / TTA1943 |
DAC | AD-1955 |
Volume controller | NJW1194 |
SNR | ≥ 95dB (A-Weighted) |
Frequency response | 20Hz-80kHz (+1/-3dB) |
THD | ≤ 0.025% (1kHz) |
Output impedance | 8Ω |
Gain | 38dB ±1dB |
Crosstalk | ≥ 75dB |
Max voltage gain | > 40dB |
Supply voltage | ~220V AC |
Dimensions (L*P*H) | 444*436*107mm |
Weight | 10.6kg |
Color | Black and silver |
Package | 1* Tonewinner AD-66D 1* IR Remote control |
Input | SPDIF |
Input | Bluetooth |
Input | HDMI |
Input | RCA |
Input | Optical |
Input | Micro SD |
Input | USB |
Output | Subwoofer |
Output | Speaker terminal |
Color | Silver |
Color | Black |
Channel | 2.1 |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 135.0 |
Remote Control | Yes |
