1 semaine que j'essaye d'opérer à des écoutes comparatives avec d'autres amplis. Rien a faire dès que je passe au LA90, j'écoute la musique.
Pour une fois, les mesures s'entendent. Une étoile en moins pour le bloc alim cheap en plastique ABS
By buying this product you get 89 loyalty points
This product has been replaced by the new version, the TOPPING LA90 DISCRET.
Amplifier 2x90W 4Ω / 1x180W 8Ω Black
Topping offers with its LA90 a powerful and efficient amplifier, which can work both in stereo and mono mode. In the first case, it is capable of delivering a power of 2x90W under 4Ω (1% THD+N), in the second it will be able to provide a power of 180W under 8Ω (1% THD+N). Moreover, the LA90 provides a combined balanced input connector, the device being able to be connected as well in Jack 6.35mm as in XLR.
The LA90 offers a whole new level of performance, revealing incredible accuracy and clarity of reproduction, with linear response and extremely low noise.
The LA90 is clad in a precision CNC machined aluminum chassis. This enclosure gives the amplifier a modern design while effectively protecting the components of the unit. The sides of the LA90 are equipped with large heat sinks, which effectively dissipate the heat emitted by the internal electronics.
The extremely low THD+N of the LA90 is measured at only 0.00007% under 8Ω 10W and 0.00008% under 4Ω 20W. These performances allow it in fact an accurate reproduction of the source signal.
The LA90 provides three balanced inputs. These have a combined format, allowing the use of both XLR and 6.35mm TRS cables. In addition, three connectors allow the device to be used in mono mode.
In order to adapt to the vast majority of audio systems, including the most demanding, the LA90 offers an adjustable gain at two levels. The first, Low Gain, offers a gain of +6.7dB, while the second, High Gain, provides a gain of +19dB.
The Topping LA90 can be configured and wired to operate in either stereo or mono mode, with the combination of two LA90s then providing higher power. When used in mono mode, the minimum impedance is 8Ω.
The volume of the LA90 can be adjusted with the large knob on the front panel. It is also possible to bypass the volume control of the LA90 in order to associate it with a HiFi preamplifier. The latter is particularly useful to synchronize the volume of two LA90s when used in mono mode.
Product type | Amplifier |
Inputs | 3x Combined Jack 6.35mm TRS / XLR |
Outputs | Speaker terminals |
Measurements | ||
Parameter | Stereo | Mono |
THD+N @ 1kHz (90kBw) | < 0.00009% @ 4Ω 5W | < 0.0001% @ 8Ω 5W |
< 0.00009% @ 8Ω 5W | ||
THD+N @ No-Weighting (90kBw) | < 0.0017% @ 4Ω 5W | < 0.0012% @ 8Ω 5W |
< 0.0009% @ 8Ω 5W | ||
SNR @ A-Weighting | 140dB | 142dB |
Dynamic range @ A-Weighting | 140dB | 142dB |
Frequency response | 20Hz-40kHz (±0.2dB) | 20Hz-40kHz (±0.2dB) |
10Hz-100kHz (±1dB) | 10Hz-100kHz (±1dB) | |
Output level | 51Vpp @ 4Ω | 98Vpp @ 8Ω |
58Vpp @ 4Ω | ||
Noise @ A-Weighting | < 2µVrms @ G=L | < 2.8µVrms @ G=L |
< 3.5µVrms @ G=H | < 5µVrms @ G=H | |
Crosstalk @ 1kHz | -138dB | - |
Input sensitivity | 6.9Vrms @ G=L | 6.9Vrms @ G=L |
2.2Vrms @ G=H | 2.2Vrms @ G=H | |
Gain | 9.5dB @ G=L | 15.5dB @ G=L |
19.2dB @ G=H | 25.2dB @ G=H | |
Channel balance | 0.2dB | - |
Output impedance | < 3mΩ | < 5mΩ |
Output power | 2x 110W @ 4Ω THD+N < 10% | 1x 220W @ 8Ω THD+N < 10% |
2x90W @ 4Ω THD+N < 1% | ||
2x 63W @ 8Ω THD+N < 10% | 1x 180W @ 8Ω THD+N < 1% | |
2x 50W @ 8Ω THD+N < 1% | ||
Load impedance | ≥ 4Ω | ≥ 8Ω |
Dimensions | 220 x 205 x 90mm |
Color | Black |
Package | 1x Topping LA90 1x Power supply 64V / 4A 1x Speaker terminals jumper cable |
Input | XLR |
Input | Jack 6.35mm |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Class | Class A / AB |
Amplifier chip | N/A |
Power (W) | 180.0 |
Power (W) | 90.0 |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Francois L.
