TOPPING LA90D Discrete Amplifier Class AB 2x120W / 1x180W 4 Ohm Black
Topping now offers the excellent LA90 in a version using discrete circuits, the LA90 Discrete. The result is a powerful amplifier with incredible metering for a breathtaking listening experience. The new NFCA discrete amplifier circuitry ensures extremely clear and precise sound reproduction. The amplifier has the same features as the first LA90, with mono or stereo operation, adjustable gain and a combined balanced input connector for 6.35mm jack or XLR.
By buying this product you get 89 loyalty points
Reference : 17500
899,00 €tax incl.
749,17 € tax excl.
Shipping date: 22-04-2025.
Topping LA90D
TOPPING LA90D Amplificateur Discret Class AB 2x120W / 1x180W 4 Ohm Noir
A robust and massive chassis
The LA90 Discrete is clad in a precision CNC machined aluminum chassis. This enclosure gives the amplifier a modern design while effectively protecting the components of the unit. The sides of the LA90 Discrete have large heat sinks, allowing the heat emitted by the internal electronics to be effectively dissipated.
High power & Low distortion
The THD+N of the LA90 Discrete is extremely low, measured at less than 0.0001% under 4/8Ω 5W. These performances allow it in fact an accurate reproduction of the source signal.
Balanced inputs
The LA90 Discrete provides three balanced inputs. The inputs have a combined format, allowing the use of both XLR and Jack 6.35mm TRS cables. In addition, three connectors allow the unit to be used in mono mode.
Topping LA90 Amplificateur 2x90W 4Ω / 1x180W 8Ω Noir
Two levels of gain
To accommodate the vast majority of audio systems, including the most demanding, the LA90 Discrete offers two levels of adjustable gain. The first, Low Gain, offers a gain of +9.4dB in stereo or +15.4dB in mono, while the second, High Gain, provides a gain of +19.4dB in stereo or +25.4dB in mono.
Mono & Stereo
The Topping LA90 Discrete can be configured and wired to operate in either stereo or mono mode, with the combination of two LA90Ds then providing higher power. When used in mono mode, the minimum impedance is 4Ω.
Volume control
The volume of the LA90 Discrete can be adjusted with the large front panel knob. It is also possible to bypass the volume control of the LA90 Discrete in order to combine it with a HiFi preamplifier. The latter is useful for synchronizing the volume of two LA90 Discrete in mono mode.
12V Trigger
The Topping LA90 Discrete is equipped with a 12V trigger input and output. It can thus be connected to other devices and allow an automatic switch on and off of them.
Product typeDiscrete amplifier
Inputs3x Combined Jack 6.35mm TRS / XLR
OutputsSpeaker terminals
Measurements
ParameterStereoMono
THD+N @ 1kHz (A-wt)< 0.00009% @ 4Ω 5W< 0.0002% @ 4Ω 5W
< 0.00009% @ 8Ω 5W< 0.0001% @ 8Ω 5W
THD+N @ 20Hz-20kHz, 90kBw (A-wt)< 0.0005% @ 4Ω 5W< 0.0007% @ 4Ω 5W
< 0.0003% @ 8Ω 5W< 0.0005% @ 8Ω 5W
SNR @ A-Weighting141dB143dB
Dynamic range @ A-Weighting141dB143dB
Frequency response20Hz-40kHz (±0.2dB)20Hz-40kHz (±0.2dB)
10Hz-100kHz (±0.4dB)10Hz-100kHz (±0.4dB)
Output level51Vpp @ 4Ω80Vpp @ 4Ω
58Vpp @ 8Ω106Vpp @ 8Ω
Noise @ A-Weighting< 1.8µVrms @ G=L< 2.5µVrms @ G=L
< 3.4µVrms @ G=H< 4.8µVrms @ G=H
Channel crosstalk @ 1kHz-138dB-
Input sensitivity7.3Vrms @ G=L6.9Vrms @ G=L
2.2Vrms @ G=H2.2Vrms @ G=H
Gain9.44dB @ G=L15.4dB @ G=L
19.4dB @ G=H25.4dB @ G=H
Channel balance0.2dB-
Output impedance< 3mΩ< 5mΩ
Output power2x 120W @ 4Ω THD+N < 10%1x 180W @ 4Ω THD+N < 1%
2x10W @ 4Ω THD+N < 1%
2x 66W @ 8Ω THD+N < 10%1x 220W @ 8Ω THD+N < 10%
2x 56W @ 8Ω THD+N < 1%1x 180W @ 8Ω THD+N < 1%
Load impedance≥ 4Ω≥ 4Ω
Dimensions220*205*90mm
Package1x Topping LA90D
1x Power supply
1x Speaker jumper cable
InputXLR
InputJack 6.35mm
OutputSpeaker terminal
Channel1 (Mono)
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipNFCA
Power (W)180.0
Power (W)120.0
6 reviews
commande et livraison et offre pour amateur audio
Merci à l équipe Audiophonic pour le sérieux; du traitement du suivie des des commandes et du délais rapide de livraison ...de vrai pro.
Très satisfait, également de votre ''catalogue de choix audio large et pertinent...Merci MO
This review has been posted for TOPPING LA90D Discrete Amplifier Class AB 2x120W / 1x180W 4 Ohm Black
idéal en multiplication
Rare sont les très bons amplis avec un contrôle de volume. Alimente avec succès une paire de AMT Radian.je ne suis pas sûr que la puissance assez contenue convienne à toutes les enceintes mais dans la configuration c est idéal et sans concurrence.
Amazing, unique device
The Topping LA90D amplifier impresses with its excellent sound quality and solid construction. With its powerful features and precise sound reproduction, it is a real asset for every hi-fi enthusiast. What is particularly impressive is the wide sound space and the clear bass reproduction, which takes the listening experience to a new level. It is truly one of the best amplifiers in the world. Recommendation !
Vielen Dank an das Audiophonics Team!
Seit 35Jahren ist HiFi für mich ein Hobby. Viele Geräte sind seit dem gekommen und auch wieder über den Gebrauchtmarkt gegangen. Was soll man sagen? Ab und zu braucht man
halt wieder was neues … Dieses Mal sollte es ein Class D Amp werden um in meinen langen
Hörsitzungen nicht so viel Strom zu verbrauchen. So groß würden meiner Meinung nach die Unterschiede nicht sein wenn man doch nur die Endstufe tauscht …dachte ich. Doch nach dem Audiophonics mir 2 verschiedene Class D Endstufen geschickt hatte wollte ich schnell wieder meine alte Endstufe zurück … doch die war bereits verkauft. Dann sind 2 von diesen kleinen LA 90 d angekommen … Und jetzt bin ich wieder sehr glücklich mit dem Klang in meinem System. Die Maximale Lautstärke ist sowieso nicht wichtig für mich und nur wenn es laut sein soll sind hier Abstriche zu machen … klar mit den kleinen Verstärkern kann man keine Bäume ausreißen. Einen LA 90 d würde ich nicht für Lautsprecher unter 88dB empfehlen … Und zwei auch nicht für Lautsprecher unter 86 dB Wirkungsgrad. Ansonsten können die alles was ein Verstärker um 5000 Euro kann … die Frage ist also nur wieviel möchten Sie ausgeben? Wie laut hören Sie? Und welche Lautsprecher haben Sie?
Excellent ampli
Ampli acheté pour ses performances S/B car utilisé sur un tweeter à ruban Viawave. Promesse tenue ! Avant cela, je l'ai testé sur mes enceintes DIY TWW, charge 2Ohm et il n'a pas bronché, même en poussant le volume, qui en passant, est suffisant, il n'est pas aussi "faiblard" qu'on semble le suggérer. En comparaison avec mes Class D Purifi (+ Sparkos), la différence est très subtile mais c'est le petit qui gagne. Je le recommande pour des enceintes avec un rendement confortable et certainement pour une utilisation dans un système actif avec des HP de la plus haute qualité.
Topping now offers the excellent LA90 in a version using discrete circuits, the LA90 Discrete. The result is a powerful amplifier with incredible...
