TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Black
20%
The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and Bluetooth receiver. An ideal model for a small or medium-sized listening room and capable of a dynamic, precise and faithful reproduction.
Reduced price!
Reference : 17420
Limited special offer
239,00 €tax incl.
-20%
191,20 €tax incl.
159,33 € tax excl.
Topping MX3S
Topping MX3S Amplificateur Class D Infineon Amplificateur Casque DAC Bluetooth aptX Adaptive 2x50W 4Ω 24bit 192kHz Noir
The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AKM AK4377 DAC and Bluetooth receiver. An ideal model for a small or medium-sized listening room and capable of a dynamic, precise and faithful reproduction.
MX3S
MX3
THD+N @ 1kHz, A-Weighted (headphone output)
< 0.003% @ 270mW, 32 Ohm
< 0.001% @ 30mW, 300 Ohm
< 0.006% @ 130mW 32 Ohm
SNR @ Max out 1kHz, A-Weighted (headphone output)
115dB
103dB
Gain (headphone output)
2dB(Vrms/FS) @ G=L
14.8dB(Vrms/FS) @ G=H
11.6dB
Noise @ A-Weighted (headphone output)
< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
< 18.0µVrms
Output power (headphone output)
2*700mW @ 32 Ohm, THD+N < 1%
2*400mW @ 64 Ohm, THD+N < 1%
2*100mW @ 300 Ohm THD+N < 1%
2*257mW @ 32 Ohm THD+N < 1%
2*42mW @ 300 Ohm, THD+N < 1%
SNR @ BTL, Max out, 1kHz, A-Weighted (sortie HP)
110dB
91dB
Noise @ BTL, A-Weighted (sortie HP)
< 60µVrms @ G=L
< 100µVrms @ G=H
< 500µVrms
An efficient Class D amplifier
The amplifier section of the MX3S uses an Infineon Merus Class D chip allowing it to deliver a power of 2x50W under 4Ω with a high efficiency higher than 90%. It also offers a characteristic restitution marked by a beautiful clarity and precision. The MX3S also offers a two-level gain control allowing it to adapt to your listening system.
Bluetooth
In addition to its complete connectivity, the Topping MX3S provides a Bluetooth receiver, allowing a remote broadcast of your music, from a smartphone or a tablet for example. The chip used supports the aptX, aptX HD and aptX Adaptive transmission codecs, promoting quality wireless sound reproduction.
Subwoofer output
With its RCA format subwoofer output, the MX3S can be used to set up a 2.1 audio system. The use of a subwoofer allows you to achieve deep and punchy bass.
Signal detection
The digital inputs of the Topping MX3S have an automatic detection of the input signal. This allows the unit to be turned on automatically when it receives an audio signal and to be turned off if no valid signal is received for one minute.
Built-in equalizer
In order to adapt to your listening and your audio system, the Topping MX3S benefits from a built-in equalizer. It allows you to adjust the bass and treble levels over a range of -10dB to +10dB.
Product typeAmplifier
Headphone amplifier
DAC
InputsBluetooth
1* Stereo RCA
1* Coaxial
1* Optical Toslink
1* USB-C
OutputsStereo speaker output
1* Subwoofer output on mono RCA
1* Jack 3.5mm headphone output
Supported sampling ratesPCM up to 24bit 192kHz
Supported Bluetooth codecsAAC, SBC, aptX, aptX-HD, aptX Adaptive
Headphone amplifier specifications
InputUSB / Optical / CoaxialAUXBluetooth (aptX Adaptive)
THD+N @ 1kHz (A-wt)< 0.003% @ 270mW, 32Ω
< 0.001% @ 30mW, 300Ω
< 0.002% @ 30mW, 300Ω
SNR @ max out, 1kHz (A-wt)115dB127dB115dB
Dynamic range @ 1kHz (A-wt)115dB127dB115dB
Frequency response20Hz-20kHz (+0.1dB/-0.3dB)
20Hz-40kHz (+0.1dB/-1.0dB)
20Hz-20kHz (+0dB/-2dB)
Output level3.4Vpp @ G=L
15.6Vpp @ G=H
10.2Vpp @ G=L
14.4Vpp @ G=H
3.4Vpp @ G=L
15.6Vpp @ G=H
Noise (A-wt)< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
Crosstalk @ 1kHz-90dB
Input sensitivity0dBFS @ G=L
0dBFs @ G=H
4.2Vrms @ G=L
1.2Vrms @ G=H
0dBfS @ G=L
0dBFs @ G=H
Gain2dB (Vrms/FS) @ G=L
14.8dB (Vrms/FS) @ G=H
-0.2dB @ G=L
12.6dB @ G=H
2dB (Vrms/FS) @ G=L
Output impedance< 0.5Ω
Output power2*700mW @ 32Ω, THD+N < 1%
2*400mW @ 62Ω, THD+N < 1%
2*100mW @ 300Ω, THD+N < 1%
Load impedance> 8Ω
Amplifier specifications
THD+N @ 1kHz (A-wt)< 0.005% @ 5W, 4Ω
< 0.004% @ 5mW, 8Ω
SNR @ max output, 1kHz (A-wt)110dB
Dynamic range @ 1kHz (A-wt)110dB
Frequency response20Hz-20kHz (+0.1dB/-0.-dB)
20Hz-40kHz (+0.1dB/-1.5dB)
Output level40Vpp @ 4Ω
44Vpp @ 8Ω
Noise (A-wt)< 60µVrms @ G=L
< 100µVrms @ G=H
Input sensitivity-2.0dBFS @ G=L
-8.0dBFs @ G=H
1.0Vrms @ G=L
0.5Vrms @ G=H
-2.0dBfS @ G=L
-8.0dBFs @ G=H
Gain26.5dB (Vrms/FS) @ G=L
32.5dB (Vrms/FS) @ G=H
24dB @ G=L
30dB @ G=H
Output impedance< 0.2Ω
Output power2*62W @ 4Ω, THD+N < 10%
2*50mW @ 4Ω, THD+N < 1%
2*40W @ 8Ω, THD+N < 10%
2*30W @ 8Ω, THD+N < 1%
Load impedance4-8Ω
Supply voltage26VDC (power supply included)
Dimensions (L*P*H)120*165*40mmmm
Package1* Topping MX3S
1* Power adapter
1* Power cable
1* USB cable
1* Remote control
1* Bluetooth antenna
OutputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Channel2.1
Amplifier chipN/A
Power (W)50.0
Remote ControlYes
4 reviews
Another happy customer
After 30 years of enjoying my father's premium JVC amplifier for my home PC setup, I finally decided it was time for an upgrade. After about a week of researching products, reading reviews, and watching videos, I settled on the MX3s. It offered exactly what I was looking for at a great price.
The package arrived in-time and well-protected in a larger box with extra-thick paper cushioning, and everything was in perfect condition. Once installed, the difference in sound quality was immediately noticeable! I could hear details in my favorite tracks that I had never noticed before—the audio quality truly feels like a whole new level.
I'm using it with my two 4ohm 30Wrms diy monitor speakers in a nearfield setup, and it’s simply perfect. The MX3s not only delivers exceptional performance but also looks sleek and stylish. I couldn’t be more satisfied with this upgrade!
This review has been posted for TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Black
Excellent rapport Qualité/Prix
Juste excellent à ce prix.
Plus de naturel et d'ouverture que le SMSL AD18 que j'avais dans cette pièce. Utilisé avec des colonnes Davis + caisson.
Très bon aussi en bluetooth.
Très agréable à l'écoute tout en restant très précis. Il n'est pas fatiguant comme peuvent l'être certains FDA en écoute longue.
Seul la sortie casque n'est pas terrible (casque AKG K701) mais je ne l'ai pas achet pour cela, c'était juste pour tester.
Très satisfait !
Acheté en remplacement d'un SMSL Q5 pro pour accompagner des Davis Eva et un caisson Yamaha NS-SW100. J'utilise ce matériel principalement dans le cadre d'une écoute "nearfield" lorsque je suis assis à mon bureau.
Ce FDA est très complet, tant par les fonctionnalités qu'il propose (écran, Bluetooth, prise subwoofer et prise casque) que par les réglages qu'il permet (aïgus, graves, extinction/allumage automatique du FDA avec le PC, extinction automatique de l'écran etc.). Sa télécommande est bien plus complète et intuitive que celle de mon Q5 Pro. L'écran est lisible et l'agencement des informations qu'il affiche est clair. En revanche, je conseille très fortement d'avoir le manuel sous les yeux lorsqu'on s'aventure les premières fois dans ses menus très peu explicites. C'est vraiment le seul petit bémol que j'ai noté jusqu'à présent, pour le reste c'est un sans faute à mon humble avis.
Concernant l'écoute, je suis très satisfait de ses prestations. Il me semble qu'il exploite beaucoup mieux le potentiel de mes enceintes. Il me paraît les diriger avec plus d'autorité et de précision que mon Q5 Pro, ce qui rend l'écoute moins fatigante par ailleurs. Cependant, n'étant ni ingénieur ni mème audiophile, je crains toujours qu'il y ait un peu d'effet placebo dans mes ressentis.
En revanche, je n'ai aucun doute sur la gestion des basses qui est clairement meilleure, tant la différence est importante, que celle de mon Q5 Pro. Je me rends compte aujourd'hui que le Q5 Pro était vraiment brouillon sur ce point. J'ai l'impression d'avoir un autre subwoofer quand je suis bien conscient d'avoir les mêmes enceintes.
Je n'ai pas encore testé la prise casque ni le Bluetooth, je n'ai donc aucune opinion sur ces points.
Pour conclure, je suis heureux de mon achat tant cette petite boîte métallique est bien finie, pratique au quotidien et agréable à mes oreilles pour l'usage que j'en fait.
Très satisfait !
The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and...
