TOPPING PA5 Balanced Class D Amplifier 2x125W 4 Ohm Black
Topping offers with the PA5 a compact yet powerful and high performance balanced amplifier. It integrates a new generation of optimized Class D amplifier circuit capable of delivering a power of 2x125W under 4Ω, with a high efficiency.
By buying this product you get 34 loyalty points
Reference : 15847
349,00 €tax incl.
290,83 € tax excl.
Topping PA5
Class D Balanced Amplifier 2x125W 4Ω Black
Topping PA5 Amplificateur Symétrique Class D 2x125W 4Ω
Topping offers with the PA5 a compact yet powerful and high performance balanced amplifier. It integrates a new generation of optimized Class D amplifier circuit capable of delivering a power of 2x125W under 4Ω, with a high efficiency. This new circuit offers a precise, neutral and rich sound reproduction, with a totally inaudible background noise. The balanced design of the PA5 also allows it to considerably limit its noise level and cancel ground loops.
Simple and efficient connectivity
The PA5 does not overdo its connectivity but proposes a simple and efficient connectivity. Thus, it offers two balanced inputs in 6.35mm TRS stereo jack format. The output is simply done on speaker terminals.
Product typeAmplifier
Inputs2x Balanced stereo Jack TRS 6.35mm
OutputSpeaker terminals (BTL output)
Output power2x140W @ 4Ω, THD+N < 10%
2x125W @ 4Ω, THD+N < 1%
2x85W @ 8Ω, THD+N < 10%
2x65W @ 8Ω, THD+N < 1%
DisplayLED
THD+N @ 1kHz, A-Weighting< 0.0005% @ 4Ω 5W
< 0.0004% @ 8Ω 5W
THD+N @ No-Weighting (20kBW)< 0.0015% @ 4Ω 5W
< 0.0006% @ 8Ω 5W
SNR @ A-Weighting124dB
Plage dynamique @ A-Weighting124dB
Frequency response20Hz-40kHz (±0.3dB)
Output level65Vpp @ RL=4Ω
68Vpp @ RL=8Ω
Noise @ A-Weighting< 16µVrms
Crosstalk @ 1kHz-106dB
Input sensitivity2.6Vrms
Gain19.1dB
Channels balance0.1dB
Output impedance< 0.01Ω
Adapter impedance3-8Ω
Supply voltage38VDC 4A
Standby consumption< 0.1W
Housing materialAluminum
Dimensions166 x 129 x 41mm
Weight680g
Package1x Topping PA5
1x Power supply
Topping PA5 Amplificateur Symétrique Class D 2x125W 4Ω Topping PA5 Amplificateur Symétrique Class D 2x125W 4Ω
InputJack 6.35mm
Channel2 (Stereo)
Amplifier chipN/A
Power (W)125.0
2 reviews
Une sonorité agréable et envoûtante sur tout le spectre.
Déjà, un tout grand merci à Audiophonics pour son sérieux. Ils ne sont pas avares de conseils et de suivi après-vente.
Pour me situer :
Tout d'abord, pour moi l'hifi, c'est une question de goût et chaque marque à souvent sa petite touche personnelle pour fidéliser le client. Moi, c'est plutôt le son des gros Technics des années 80 ou les NAD, qui me plait, parce que ça a du punch sans être agressif.
Je ne suis pas à mon premier Class D, mon ampli Class AB acheté d'occasion vient de me lâcher, donc je ré-inspecte le marché pour en acquérir un neuf et le PA5 faisant beaucoup de bruit sur la toile.
Mon impression toute subjective :
Le PA5 est une belle surprise, la définition et la netteté est surprenante, c'est vraiment une belle sonorité qui me fait penser à ce que fait Marantz. C'est propre sur tout le spectre, tout est bien délié, le piano ressort très bien dans les œuvres orchestrales, rien ne semble noyé. C'est un ampli qui parait avoir beaucoup de subtilité et de délicatesse. Pour ce qui est du relief musical, il est excellent, lorsque l'enregistrement le permet, on est bien immergé dans une large scène sonore.
Le grave est très bien maîtrisé également.
Ma seule déception est au niveau du punch, ce n'est pas le son des NAD ou des gros Technics. Mais ce « problème », je l'ai constaté sur tous les Class D que j'ai eu et entendu et surtout, il est à relativiser. Je crois que j'exagère avec ça.
Pour moi, un ampli doit être capable de me faire sursauter lors de brusques montées.
Celui-ci, moins (mais il le fait quand-même un peu).
Cela dit les attaques sont bien franches, question articulations ça passe très bien, tout ce qui est darbouka, djembé, bendir, … me remue avec beaucoup de détails.
Le grave est aussi surprenant, il est bien présent est ferme et ce, quel que soit le volume.
Le plus surprenant est son homogénéité, tout le spectre semble traité en toute impartialité, c'est vraiment très équilibré !
Pour la sonorité, en résumé :
Elle me fait réellement penser à ce que fait Marantz dans le plus haut de gamme : C'est équilibré, propre, net, doux (mais nerveux quand il le faut), détaillé, vif (mais sans excès). C'est assez loin du son du PA3, qui a ses qualités, mais souffre d'un manque de vivacité et autres petits détails
On peut dire que le son qui sort du PA5 est assurément très agréable, envoûtant même !
Question pratique :
Comme les entrées sont symétriques et mes éléments asymétriques, je pensais prendre un transformateur (boitier direct) mais la puissance est suffisante en asymétrique pour la taille de mon appartement et la sensibilité de mes hauts-parleurs. Dans le cas de haut-parleurs peu sensibles, symétriser le signal me paraît indispensable pour gagner du gain.
Sentiment de mon achat :
Même si j'ai eu une petite déception sur le punch (qui ne semble tenir qu'à ma perception), tout le reste n'est qu'enchantement et surtout, comme souvent chez Audiophonics, je n'ai pas dû étrangler mon portefeuille, à 350 €, je ne pouvais rien espérer d'exceptionnel sur le marché classique. Les premiers amplis qui me plaisaient commençaient autour des 500 € et plus. Ici, j'ai l'impression d'être avec un ampli que j'aurais dû payer plus de 800 €
Bref, sa réputation sur le Web n'est pas usurpée !
This review has been posted for TOPPING PA5 Balanced Class D Amplifier 2x125W 4 Ohm Black
Believe the hype!
I bought this unit with guarded optimism based on the reviews, some actually saying that it provides a deeper soundstage than the D90, and sounding as good as units costing several times as much.
I wanted a DAC that not just sounded good, but has Bluetooth connectivity , can be used as a pre amplifier, and offers MQA and DSD. Not that Read more about review stating Believe the hype! , but I'd rather have it and not need it, - I didn't want to be limited to FLAC only if I should decide to try other codec formats.
I currently also own a Schiit Yggdrasil A2, RME ADI2 DAC FS, Burson Soloist 3X ,Cayin HA1AMK2 amp, Monolith THX AAA Desktop DAC/Amplifier, Topping D50& A50, Topping A90, XDUOO TA-20, and have owned a Sennheiser HDVD 800, Darkvoice 336SE with a ton of tubes.
Headphones include Sennheiser HD6XX and HD800S, Audeze LCD-XC and LCD-4, and others, and too many IEM's to list.
I haven't used the D70S as a pre amplifier yet, strictly as a DAC for USB FLAC only.
Quite frankly, I am stunned.
I didn't expect it to sound THAT good!
With the D50 and RME- I NEVER GOT LOST IN THE MUSIC.
I was always acutely aware of a digital glare, perhaps even overly analytical. I wasn't listening to the music. I was listening to digital playback of music.
As far as MY ears can tell- and I'm 56- so I probably don't hear as well as some of you younger people, this DAC stood tow to toe against the mighty Yggdrasil A2.
WT?
I've stated many times in other forums that I'm a HUGE fan of the Schiit Multibit sound, from the Bifrost and up.
Well, D70S made me a believer in Delta Sigma type DACs.
I can't believe that this day would ever come, where I would be endorsing a CHIFI device so enthusiastically.
Get it. It's gonna be all the DAC you could possibly appreciate, and for MOST people, will be the strongest link in the audio chain.
Topping offers with the PA5 a compact yet powerful and high performance balanced amplifier. It integrates a new generation of optimized Class D...
