Topping's PA5 II Plus amplifier is a compact and powerful model, adopting a totally balanced structure and an innovative Class D amplifier circuit, enabling it to develop a significant power of 2x125W into 4Ω with a low level of distortion. The excellent parameterisation carried out by the brand's engineers ensures clear, clean and deep sound reproduction, with no background noise. At 5W and 4Ω, THD+N is measured at less than 0.0004%.
The PA5 II Plus also incorporates an effective and comprehensive protection circuit, acting against overvoltage, undervoltage, short-circuit, overcurrent and overheating.
On the input side, there is a choice of single-ended stereo RCA or two 6.35mm TRS jacks for balanced input. Output is via conventional speaker terminals that accept banana plugs. There's also a 12V trigger on the rear of the unit, enabling the PA5 II Plus to be connected to other devices to take advantage of the automatic on/off function.
To use the 12V trigger function, it must be activated using the switch on the front of the device.
1 | ON-OFF / Trigger switch |
2 | ON/OFF LED indicator |
3 | Input selector |
4 | Volume button |
5 | Balanced Jack 6.35mm TRS left channel input |
6 | Single-ended RCA left channel input |
7 | Speaker R+ output |
8 | Speaker HP L+ output |
9 | Power input |
10 | Balanced Jack 6.35mm TRS right channel input |
11 | Single-ended RCA right channel input |
12 | Trigger 12V Jack 3.5mm input |
13 | Speaker R- output |
14 | Speaker L- output |
Product type | Amplifier |
Amplification type | Class D |
Inputs | Single-ended stereo RCA Balanced Jack 6.35mm TRS |
Output | Speaker terminal |
Trigger | 12V |
Balanced input measurements | |
THD+N (@ 1kHz, A-Weighted) | < 0.0004% @ 4Ω 5W < 0.0003% @ 8Ω 5W |
THD+N (@ No-Weighted, 20kBW) | < 0.0015% @ 4Ω 5W < 0.0006% @ 8Ω 5W |
SNR | 124dB (@ max out, 1kHz, A-Weighted) |
Dynamic range | 124dB (@ 1kHz, A-Weighted) |
Frequency response | 20Hz - 40kHz (±0.3dB) |
Output level | 65Vpp @ 4Ω 68Vpp @ 8Ω |
Noise | < 15µVrms (@ A-Weighted) |
Crosstalk | -106dB (@ 1kHz) |
Input sensitivity | 2.6Vrms |
Gain | 19.2dB |
Channel balance | 0.1dB |
Output power | 2x140W @ 4Ω, THD+N < 10% 2x125W @ 4Ω THD+N < 1% 2x85W @ 8Ω, THD+N < 10% 2x65W @ 8Ω, THD+N <1% |
Single-ended input measurements | |
THD+N (@ 1kHz, A-Weighted) | < 0.0005% @ 4Ω 5W < 0.0004% @ 8Ω 5W |
SNR | 121dB (@ max out, 1kHz, A-Weighted) |
Dynamic range | 121dB (@ 1kHz, A-Weighted) |
Crosstalk | -90dB (@ 1kHz) |
Input sensitivity | 1.3Vrms |
Gain | 25dB |
Supply voltage | 38VDC 3A |
Standby consumption | < 0.5W |
Dimensions (W*D*H) | 129*166*41mm |
Weight | 680g |
Color | Black |
Package | 1* Topping PA5 II Plus 1* Power supply |
Input | Jack 6.35mm |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 125.0 |
Remote Control | No |
