TOPPING PA7 PLUS Amplifier Class D Balanced 2x245W 4 Ohm Black
The Topping PA7 Plus is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a significant power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of the PA7 Plus provides effective transmission noise reduction.
By buying this product you get 51 loyalty points
Reference : 17645
519,00 €tax incl.
432,50 € tax excl.
Topping PA7 Plus
Topping PA7 Plus Amplificateur Class D Symétrique 2x245W 4Ω Noir
Comparison between Topping PA7 and PA7 Plus
PA7 Plus
PA7
Output power
2*245W @ 4, THD+N < 1%
2*135W @ 8, THD+N < 1%
2*200W @ 4Ω, THD+N < 1%
2*125W @ 8Ω, THD+N < 1%
SNR
124dB
123dB
Dynamic range
124dB
123dB
Input sensitivity
Single-ended: 2Vrms
Balanced: 4Vrms
Single-ended: 1.9Vrms
Balanced: 3.8Vrms
Output level
90Vpp @ 4
91Vpp @ 8
83Vpp @ 4
89Vpp @ 8
Incredibly low distortion level
The PA7 Plus's performance in terms of distortion is close to that of a very good DAC. It always remains extremely low before clipping, ensuring a constant reproduction quality whatever the volume level.
Impressive power
The PA7 Plus, despite its compactness, is capable of delivering a significant power. It will indeed be able to deliver no less than 2x245W under 4Ω (1% THD+N) or 2x135W under 8Ω (1% THD+N). It is thus capable of powering greedy audio systems without difficulty while offering a beautiful dynamic.
Single-ended & balanced Inputs
The Topping PA7 Plus provides a double input connector. There is an XLR / Jack 6.35mm TRS combo for balanced transmission and a stereo RCA input for single-ended transmission.
Volume bypass
The Topping amplifier has a volume control. It is however possible to bypass this control to use the PA7 Plus as a power amplifier, by associating an external preamplifier (not supplied).
12V Trigger
Equipped with a 12V trigger input, the PA7 Plus can be connected to other devices to take advantage of an automatic on/off function of the system set up.
Topping PA7 Plus review by Audio Science Review (Amir)
" Even though the PA7 Plus is based on a commercial amplifier IC, it is clearly that significant engineering optimizations have gone into the design to produce such a low noise and distortion amplifier. The package is excellent and power supply quite hefty to enable very high power output (nearly 400 watts combined at 4 ohm!). I am happy to add Topping PA7 Plus to my recommend list. "
Test du Topping PA7 Plus par Audio Science Review (Amir)
Product typeAmplifier
Amplification typeClass D
Inputs1* Balanced stereo XLR/TRS combo
1* Single-ended stereo RCA
OutputSpeaker outputs
Measurements
Single-endedBalanced
THD+N @ 1kHz (A-weighted)< 0.0005% @ 4Ω, 20W
< 0.0004% @ 8Ω, 20W
< 0.0004% @ 4Ω, 20W
< 0.0003% @ 8Ω, 20W
THD+N @ 20kBw (No-weighted)< 0.009% @ 4Ω, 20W
< 0.004% @ 8Ω, 20W
< 0.009% @ 4Ω, 20W
< 0.004% @ 8Ω, 20W
SNR @ Max out, 1kHz (A-weighted)124dB127dB
Dynamic range @ 1kHz (A-weighted)124dB127dB
Frequency response20Hz-40kHz (±1.5dB)20Hz-40kHz (±0.3dB)
Output level90Vpp @ 4Ω
91Vpp @ 8Ω
90Vpp @ 4Ω
91Vpp @ 8Ω
Noise (A-weighted)< 17µVrms< 17µVrms
Crosstalk @ 1kHz-96dB-116dB
Input sensitivity2Vrms4Vrms
Gain25.7dB19.8dB
Channel balance0.5dB0.5dB
Output power2*300W @ 4Ω, THD+N < 10%
2*165W @ 8Ω, THD+N < 10%
2*245W @ 4Ω, THD+N < 1%
2*135W @ 8Ω, THD+N < 1%
Load impedance4-8Ω
Dimensions (L*P*H)200*155*41mm
Package1* Topping PA7 Plus
1* Supply voltage
InputJack 6.35mm
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipN/A
Power (W)245.0
The Topping PA7 Plus is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design....
