TOPPING TP32EX Amplifier TK2050 2x 10W 8 Ohm / Headphone Amplifier / DAC
Reference : 8405
149,00 €tax incl.
124,17 € tax excl.
The TP32EX is designed with high quality electronic components and has a front LED display.
Based on a Class-T Tripath architecture with a TK2050 chip, this T-amp delights you with its precise and dynamic sound, despite its maximum power of about 2x15W.
It is enough for moderate volume listening, even on low-efficiency 88 dB speakers.
Il integrates a Cirrus Logic CS4392 converter, a USB VT1620 interface and a CS8416 S / PDIF receiver.
Pilotable with its IR remote control.
Features:/ Strong>
  • Class T Amplifier: Tripath TK2050 of 2x15 Watts
  • Output power: 2 x 15W @ 4 ohms, 2 x 10W @ 8 ohms
  • Frequency response: 20Hz - 20kHz
  • IHF-IM Distortion: 0.1% @ 1W, 4ohm
  • THD Distortion: 0.045%
Headphone Amplifier:
  • Output Power: 140mW @ 32ohm
  • THD Distortion: 0.002% @ 45mW, 32ohm
DAC USB:
  • Cirrus Logic CS4392
  • THD Distortion: 0.0057% @ 1kHz
  • Sampling rate: 24bit / 192kHz
Components:
  • Volume control: CS3310
  • TOKO
  • ALPS
  • Resistance KOA
  • Nichicon Capacitors
  • Relay TAKAMISAWA
  • Power supply: DC 12V 3A, 5.5 / 2.1mm
  • Inputs: RCA, Coaxial S / PDIF, USB-B
  • HP compatible terminal strip outputs
  • Headphone output 6.35mm
  • Comes with remote control, 3.5mm to 6.3mm jack adapter and power supply
  • Dimensions: 15x45x200mm
  • Weight: 700g
[Img-10031-left-large_default]
[Img-10032-left-thickbox_default]
[Img-10033-left-thickbox_default]
[Img-12034-left-thickbox_default]
