WONDOM AA-AS32157 Amplifier Tripath TA2024 Class D 2 x 15W / 4 Ohm
Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity.
4.6 / 5
Reference : 11845
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 15-04-2025.
Wondom AA-AS32157
Amplifier Tripath TA2024 Class D 2 x 10W / 8 Ohm
Wondom AA-AS32157 Amplificateur Tripath TA2024 Class D 2x10W 8Ω
Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x10W under 8Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity. An excellent value for money, allowing you to drive various passive speakers 4Ω or 4Ω.
Product typeAmplifier
Amplification typeClass D
Amplification moduleTripath TA2024
Power2x15W @ 4Ω, THD+N < 10%
2x10W @ 8Ω, THD+N < 10%
Efficiency> 90% @ 8Ω
Input1x Stereo RCA
OutputSpeaker terminals (accept banana plugs)
Frequency response20Hz - 22kHz
SNR90dB
LED Status indicator
Volume control
ProtectionsOvercurrent
Overvoltage
Over heat
Power supply9-14VDC via Jack DC (power supply sold separately)
Housing materialAluminium
Dimensions120 x 74.6 x 49mm
Channel2 (Stereo)
Amplifier chipTA2024
Power (W)15
5 reviews
Excellente petite machine.
J'ai commandé ce petit ampli sur la foi de différents avis indépendants, et aussi parce que j'avais remarqué la musicalité du ta2024.
Je n'ai pas été déçu...
En fait, j'ai ensuite commandé un deuxième ampli en secours, tant le résultat m'a plu.
Puis, tout bien réfléchi, j'ai installé un ampli par canal, afin de solliciter au minimum l'alimentation.
Donc j'utilise le canal droit de chaque ampli.
J'ai mis une résistance de 100 Ohms sur chaque canal gauche, au cas où il lui viendrait des envies d'oscillations, les amplis en classe D détestent les boucles ouvertes en sortie.
Le passage en deux blocs mono m'a fait gagner à l'écoute sur pratiquement tous les paramètres. Pour le prix de ces deux minuscules amplis, je ne sais ce que je pourrais leur opposer.
Un seul petit reproche : l'un des amplis a son bouton de volume collé ou trop serré, et si je voulais - après la garantie - améliorer l'alimentation, ou la rénover, je ne peux pas ouvrir l'appareil, de peur d'endommager le codeur optique.
Si quelqu'un a une solution, je suis preneur...
Sinon, mes enceintes ont un rendement pas trop mauvais, avec 91 dB. J'imagine que les 81 dB des Kef 101 d'autrefois seraient moins à l'aise...
Là, dans une pièce de 25 M2, un volume confortable est atteint et même dépassé sans problème.
Merci pour ces magnifiques petites trouvailles !
This review has been posted for WONDOM AA-AS32157 Amplifier Tripath TA2024 Class D 2 x 15W / 4 Ohm
Bon ampli
Bien construit et performant. Satisfait de mon achat. Reçu rapidement et bien emballé. Merci à audiophonics.
Excellent petit ampli, basique mais performant ! Chaudement recommandé
Sonorité clean et agréable, satisfait de ce petit achat :-)
Chez moi, petit ampli de secours, pour l'instant essayé en association avec un "The Preamp" de Musical Fidelity et des enceintes Rogers Ls2A/2 au rendement de 87db, il est bien assez puissant et s'en sort plutôt bien. Sa sonorité est clean et agréable, bien plus naturelle que les petits amplis au même prix que l'on trouve sur les grands sites marchands.
Satisfait de mon achat :-)
Très bon
Après être tombé sur des commentaires dithyrambiques au sujet de certains amplificateurs Class T comme feu le regretté Poppulse T180, poussé par la curiosité je passe commande de ce cet ampli Sure/WONDOM doté d'une puce TA2024.
Je reste un peu inquiet et dubitatif quant à la faible puissance annoncée en 8 ohms...10W...c'est peu...! Je crains que cela grille les bobines de mes enceintes à petit feu.
Mais je ne suis pas un adepte de Heavy Metal avec le curseur poussé à fond, j'écoute avant tout de la musique acoustique, essentiellement du Jazz dans toute sa diversité, instrumental, vocal, de la musique cubaine...etc. J'aime entendre vibrer les cordes de contrebasse, sonner le cuivre du trombone, claquer les peaux des congas...
J'ai couplé notre petit ampli au buffer à lampes Fx-Audio Tube 01que j'avais commandé avec, il apporte beaucoup de gain, et là au fil des heures d'écoute, ce petit ampli se révèle être une vraie merveille. La scène sonore est aérée, détaillée, équilibrée à tous les niveaux du spectre. A mon humble niveau, mais doté pour le moins d'oreilles exigeantes, on atteint à une vraie qualité audiophile.
Maintenant reste la question de la durabilité, mais seul le temps permettra de le dire...
Une petite question à Audiophonics: peut-on espérer le retour d'amplificateurs Class T dotés de la puce TA2020 réputée également pour sa musicalité? D'avance merci.
 (6)
Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks...
