XDUOO DA-100 Class D Amplifier TPA3116 DAC ES9018K2M Bluetooth 5.0 aptX HD LDAC 2x50W
The xDuoo DA-100, although compact and affordable, is very versatile, taking on the functions of Class D amplifier, headphone amplifier and DAC. Its careful design embeds a TPA3116 amplifier allowing it to develop a 2x50W power, a MAX97220 headphone amplifier and a ES9018K2M DAC ensuring low distortion and high SNR. A 1.3" OLED screen displays information about the playback, such as the volume level, the sampling rate of the played file or the title of the song.
Reference : 16546
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 29-04-2025.
xDuoo DA-100
xDuoo DA-100 Amplificateur Class D TPA3116 DAC ES9018K2M Bluetooth 5.0 aptX HD LDAC 2x50W
In terms of connectivity, the input is USB-C, but there is also Bluetooth 5.0 reception, allowing you to broadcast your music remotely, from a smartphone or tablet for example. The embedded Bluetooth chip also supports the aptX, aptX HD and LDAC transmission codecs, for high-quality wireless sound reproduction.
Product typeAmplifier
InputsBluetooth 5.0
1x USB-C
OutputsSpeaker terminals
1x Jack 6.35mm headphone output
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Bluetooth range10m
Amplification chipTPA3116
Headphone amplifier chipMAX97220
DAC chipES90181K2M
Output powerSpeaker output: 2x50W
Headphone output: 125mW @ 1kHz, 32Ω
THD+NSpeaker output: 0.1%
Headphone output: 0.05%
CrosstalkSpeaker output: 90dB
Headphone output: 75dB
SNRSpeaker output: 90dB
Headphone output: 110dB
Recommended headphone impedance16~300Ω
Supply voltage24VDC
Dimensions196 x 121 x 48mm
Weight700g
Package1x Xduoo DA-100
1x Bluetooth antenna
1x 3.5mm jack to 6.35mm jack adapter
1x USB-A to USB-C cable
1x 24V 3A power adapter
OutputJack 6.35mm
OutputSpeaker terminal
ColorGray
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)50.0
The xDuoo DA-100, although compact and affordable, is very versatile, taking on the functions of Class D amplifier, headphone amplifier and DAC....
