AUDIOPHONICS CMD-3 Kit Stereo Modulation Cable 3m
4.0 / 5
Reference : 2352
52,00 €tax incl.
43,33 € tax excl.
Audiophonics Galileo CMD3 DIY Modulation Cable
Audiophonics markets its audio cables in kit so you can enjoy the quality of its equipment at a lower cost.
All necessary components are supplied to build a cable identical to the mounted version
Sommercable GALILEO 238+
1877 PHONO ZSP-4
Viablue Splitter NF-A7
Viablue Braided sheath Red Welding Mundorf Silver-Gold 4%
  • High torsional strength and very long service life thanks to the thick coating and the encapsulation of the pairs of conductors in the PVC
  • Absolutely neutral and lossless audio transmission thanks to extra-thin copper strands
  • Excellent screen formed by double helical shielding very dense and with reciprocal twist
  • Very flexible thanks to short-wiring of cores and conductors
  • Important section (2 x 0.38 mm2), allowing lossless retransmissions over long distances
  • Braided nylon outer sheath
  • Anodized aluminum splitters give the cable a professional finish
  • Top-of-the-range connectors 1877 Phono ZSP-4
Mounting diagram
https://www.audiophonics.fr/images2/2350/2350_AP_CMD3_1.jpg
https://www.audiophonics.fr/images2/2350/2350_AP_CMD3_2.jpg
Kit Câble RCA
Bonne affaire, acheter le matériel séparément revient à plus de 72€
Il faut procéder avec soin pour montrer les RCA
Qui sont trop petites et fragiles de mon point de vue.
Premiers essais ; câble assez mât sans être plat
Il me semble qu il enlève un peu de brillance au son
Pas forcément négatif avec un DAC analytique ES9018 et ampli à tubes....
This review has been posted for AUDIOPHONICS CMD-3 Kit Stereo Modulation Cable 3m
