![](https://www.audiophonics.fr/img/cms/1-metre.jpg)
Mogami W2319 cable is a high impedance transmission cable, perfectly suited for music applications and instruments. As for example electric guitars which consist of high-impedance circuits driven by the voltage.
Ce cable has been designed to have very low microphone effects thanks to its layer of conductive PVC placed under the shielding conductor. This property is very sought after especially for equipping musical instruments.
The isolation conductors is made of PE (Polyethylene), known for its excellent electrical characteristics, as well as a black PVC outer sheath bringing the cable up to 5mm in total diameter.
Herconstruction is robust and flexible, allowing easy cable handling regardless of application and requirements.
You will find in the documents enclosed below a PDF detailing the technical characteristics of the cable.
Main Features :
- 0.305mm² conductor (# 23AWG) Li>
- PE conductor insulation (Polyethylene): Ø 1.6mm
- Upper insulation: Conductive PVC Ø 1.8mm
- Black PVC sleeve
- Overall outer diameter: Ø 5mm
- Flexible and robust construction
- Sold by the meter Li>
FEATURESELECTRIC & MECHANICAL ERRORS
Part No. | W2319 |
DC Resistance at 20 ° C </ Td> | Inner Conductor | 0.064Ω / m (0.020W / Ft) </ Td> |
Shield Conductor | 0.026Ω / m (0.0079Ω / Ft) |
Capacitance at 1kHz, 20 ° C </ Td> | 155pF / m (47.3pF / Ft) |
Inductance | 0.3μH / m (0.092μH / Ft) |
Electrostatic Noize * | 0.13mV Max. |
Electromagnetic Noise At 10kHz * | 0.07mV Max. |
microphonics * | 0.3mV Max |
Voltage Breakdown | Must withstand at DC 500V / 15sec. |
Insulation Resistance | 100000 MΩ × m Min. at DC 500V, 20 ° C |
Flex Life | 11,000 cycles | </ Td> |
Tensile Strength (26 ° C, 65% RH) </ Td> | 303 N | Td> |
Emigration | Non-emigrant to ABS resin |
Applicable Temperature | -20 ° C~ + 60 ° C (-4 ° F. + 140 ° F) |
![MOGAMI W2319 Câble MOGAMI W2319 Câble](https://www.audiophonics.fr/img/cms/cable%20description-2.jpg)
