NEOTECH NEI-2002 Interconnect Cable UP-OCC Pure Silver Triple Shielded Ø11mm
Neotech's NEI series is a range of high-end cables. The NEI-2002 cable features two pure silver single-core conductors, both with a diameter of 0.58mm (AWG 23). NEI-2002 features a triple shielding layer with microporous PTFE, AL-Mylar and silver-plated OFC braiding.
Reference : 18057
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 25-04-2025.
Câble vendu au mètre
NEOTECH NEI-2002
NEOTECH NEI-2002 Câble de Modulation Argent Pur Up-OCC Triple Blindage Ø11mm
Neotech's NEI series is a range of high-end cables. The NEI-2002 cable features two pure silver single-core conductors, both with a diameter of 0.58mm (23AWG). NEI-2002 features a triple shielding layer with microporous PTFE, AL-Mylar and silver-plated OFC copper braiding. The insulation is air-insulated, with 5 PE air-insulation tubes of 1.8mm diameter and a layer of PTFE. A PVC outer jacket and a covering braided nylon sheath then cover the whole for a perfect finish. The outer diameter of Neotech's cable is Ø11mm. This high-end cable is perfect for your audiophile projects.
NEI-2002 cable structure by Neotech
1Pure silver conductor
2PE insulation
3PE tube
4PTFE tape
5AL-Mylar
6Braided silver-plated OFC copper
7Paper
8PVC outer jacket
9Braided nylon outer sheath
Product typeModulation cable
Conductor materialPure silver UP-OCC
Number of conductors2
Conductors section0.26mm² (23AWG)
ShieldingMicroporous PTFE
AL-Mylar
Braide silver-plated OFC copper
InsulationPE air tubes and PTFE
External sheathsPVC
Braided nylon
Outer diameterØ11mm
ColorGreen and black
PackageSold by the meter
Diameter (mm)11.0
Insulation materialPE
Insulation materialPTFE
ShieldingYes
Section (mm²)0.26
Conductors material (Cable)Silver
Ground / ShieldingYes
Neotech's NEI series is a range of high-end cables. The NEI-2002 cable features two pure silver single-core...
