AMANERO COMBO768 USB Digital Interface
The Combo768 is an USB audio device adapter designed for OEM applications. USB PCM audio data (2 channels) accepted as input are converted into an I2S stream or a native DSD stream. Supported PCM sampling frequencies range from 44.1kHz to 1536kHz. The maximum sample rate can be limited to 192kHz, 384kHz, or 768kHz. The DSD format is decoded both in DoP format (FA05 token) and in native format. In DoP format, the maximum sample rate is DSD512, while in native DSD format, the maximum sample rate is DSD1024.
Reference : 19078
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 24-04-2025.
AMANERO COMBO768 Digital interface USB 1536kHz to I2S / DSD
AMANERO COMBO768 Digital interface USB 1536kHz to I2S / DSD : Front view
The Amanero Combo768 is an USB audio interface designed for OEM applications. USB PCM audio data (2 channels) accepted as input are converted into an I2S stream or a native DSD stream. Supported PCM sampling frequencies range from 44.1kHz to 1536kHz. The maximum sample rate can be limited to 192kHz, 384kHz, or 768kHz. The DSD format is decoded both in DoP format (FA05 token) and in native format. In DoP format, the maximum sample rate is DSD512, while in native DSD format, the maximum sample rate is DSD1024.
On Windows, no kernel mode drivers are required, as system USB drivers are used, ensuring they are always up to date. Additionally, a ASIO driver is provided to support native DSD from DSD64 to DSD1024. On Linux, with a kernel supporting native DSD, you can achieve up to DSD1024. Native DSD support in Linux is constrained by the USB VID/PID. The Combo768 base board uses VID=0x16d0 and PID=0x0A23, values already included in many Linux distributions as enabled for native DSD. Clock signals can be generated by two low phase noise oscillators at 45.1584MHz/49.152MHz or directly from the 24MHz XTAL that powers the CPU.
The CPU is a Cortex-M7 NXP IMXRT1011 and the external flash is W25Q32. The power supply requires 3.3V and 1.2V. An incoming DSD stream is indicated by an asserted signal in a specific DSD ON pin of the output comb connector and the I2S DATA and I2S FSCLK pins become the DSD Left/Right output pins.
The module works in Master Mode only.
Type of productDigital Interface
InputsUSB-B
OutputsSoldering pads I2S / native DSD
Sampling rateI2S: 44.1kHz 48kHz, 88,2kHz, 96kHz, 192kHz, 352.8kHz, 384kHz, 705,6kHz, 768kHz, 1411,2kHz, 1536kHz
DoP: DSD64, DSD128, DSD256, DSD512
Native DSD: DSD64, DSD128, DSD256, DSD512, DSD1024
Output formatI2S
DSD64 - DSD1024
ClocksXO 49.1520 MHz Low phase noise
XO 45.1584 MHz Low phase noise
OSNo driver needed for Mac Os 10.6 + or Linux (UAC2 kernel-compatible)
Windows driver required for native DSD support from DSD64 to DSD1024
OutputSolder pad
Max sampling rate1536kHz
Max sampling rateDSD1024
Interface chipARM Cortex-M7
AMANERO COMBO768 Digital Interface USB 1536kHz to I2S / DSD
The Combo768 is an USB audio device adapter designed for OEM applications. USB PCM audio data (2 channels) accepted as input are converted into an...
