Mon 2eme exemplaire.
Quand on aime...
Interface USB SPDIF - 32bit / 384kHz - Asynchronous - OTG
The Hecate Xmos Xcore 208 Asynchronous USB / SPDIF Frame features the latest in high-resolution digital technology. This interface includes dual isolation galvanic isolation with 2x4 channels, guaranteeing the 1000 MIPS of computing capacity of the new processor XMOS Xcore 208, that is twice the capacity of the XMOS U8 older generation.
Thehas design quality of USB interface Armature Hecate uses the best electronic components. You can certainly say that you are in the company of one of the best USB interfaces on the market.
Thea I2S output on AMANERO compatible solder pins allows transmission of files up to 32bit / 384KHz and DSD 256. This allows the maximum resolution of the 32 bit Bitless DAC with a very low jitter.
The original Xilink integrated processor which lowers the fully programmed output jitter allows very high resolution decoding on a 4-layer printed circuit board. The alliance of the high-transfer galvanic bridge, of the two Crystek low-noise phase oscillators provides analytical capability, enhanced readability for any quality 24/32bit DAC. Here is a USB / SPDIF interface that will renew your musical experience.
This state-of-the-art XMOS processor has 4 times the computing power of the old XMOS U8. The result: Greater definition combined with a very low jitter. XMOS Chips are a reference in this field and recognized time and again by the audiophile world.
The two oscillators of 22.57Mhz (multiple of 44.1Khz) and 24.57Mhz (multiple of 48khz)Crystek CCHD-575-25 ensures a very low jitter rate and increased accuracy. The result is immediately audible with a very high definition without tension, a respect of the stamps well above the competitors USB interfaces.
The combination of the high-transfer galvanic bridge and the two low phase noise Crystek oscillators provides analytical capability and enhanced legibility for any high-quality 24 / 32bit DAC. Here is a USB / SPDIF interface that will renew your musical experience.
Processor | Xilink with dedicated audio algorithm |
USB Interface | XMOS Xcore 208 1000 MIPS |
Plating | SPDIF Gold Plated Digital Output Connector |
Galvanic insulation | Double: current and digital |
Compatibility | Native / Plug & Play on Linux UAC2, OS X / OTG |
x3: Play, DSD, Power | |
Input Sampling Rate (XMOS Xcore 208) | 16 / 24bit up to 192kHz |
Output Sampling Rate | SPDIF coaxial plated Gold: 75Ω, 24bit and 192kHz max / I2S on PCB (supplied PIN): up to 32bit 384kHz and DSD256 |
PCB Dimensions | 97 x 50mm |
Coaxial dimensions | 64 x 25mm |
This USB interface has an I2S output on PIn (connector provided) to be welded.
I2S PIN connection on the interface.
Input | USB |
Output | Coaxial SPDIF |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
Color | Black |
Channel | 2 (Stereo) |
Interface chip | XMOS XCore U208 |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean S.
Boris B.
Tomas H.
Patrick R.
Jean Louis G.
