Digital Interface Module USB to SPDIF Coaxial Optical I2S SA9123 24bit 192kHz
This module is a digital interface featuring a USB-B 2.0 input, as well as two SPDIF outputs in coaxial and optical Toslink format and one output I2S 5-pin. The interface is based on an SA9193 chip that supports PCM sampling rates up to 24bit 192kHz.
Reference : 17932
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 22-04-2025.
Digital INTERFACE module
USB to SPDIF Coaxial/Optical I2S SA9123 24bit 192kHz
Interface Numérique I2S/USB vers SPDIF Coaxiale/Mini Toslink SA 9123 24bit 192kHz
This module is a digital interface featuring a USB-B 2.0 input, as well as two SPDIF outputs in coaxial and optical Toslink format and one I2S 5-pin output. The interface is based on an SA9193 chip that supports PCM sampling rates up to 24bit 192kHz
This module requires a driver for use with Windows 7.
Digital Interface I2S/USB to SPDIF Coaxial/Toslink SA 9123 24bit 192kHz
Product typeDigital interface
Inputs1* USB-B 2.0
Outputs1* Coaxial
1* Optical Toslink
1* I2S 5-pin
Supported sample ratesPCM up to 24bit 192kHz
Interface chipSA9123
CompatibilityWindows 7 (with driver)
Windows 10 (without driver)
Supply range1.8V to 3.3V
Dimensions62*35 mm
Weight16g
Interface Numérique I2S/USB vers SPDIF Coaxial/Toslink SA9227 32bit 384kHz DSD256 AC3 DTS
OutputOptical Toslink
OutputI2S
OutputCoaxial SPDIF
Max sampling rate192kHz
This module is a digital interface featuring a USB-B 2.0 input, as well as two SPDIF outputs in coaxial and optical Toslink format and one output...
