USB to I2S ARM CPLD 32bit 384kHz DSD512
This high quality USB to I2S interface module allows you to get an I2S/DSD output from a USB computer source. Associated with a DAC with I2S input, it allows you to create a complete product that can be read from a PC, Mac or Linux source. It works with an ARM Cortex M3 ATSAM3U processor and processes the signals using a XILINX CPLD model XC2C64A. These use two low phase noise TCXO clocks 24.5760 & 22.5792Mhz. This allows the module to interface high sample rates (up to 384Khz / DSD512) with low jitter.
Technical characteristics | |
Product type | Digital interface |
Chipset | ARM® Cortex®-M3 ATSAM3U CPLD XILINX® XC2C64A |
Clocks | 2x TCXO |
Input | USB-B |
Output | I2S |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD512 |
Output format | I2S 32bit or DSD64,DSD128 - and Native DSD256,DSD512 under windows |
Support | No drivers required |
Windows systems | KS / Wasapi / WDM/ASIO |
PCB Dimensioons | 30x69 mm |
