Digital Interface USB to I2S / SPDIF / Jack 3.5mm PCM2707C 16bit 48kHz
This affordable USB to I2S digital interface module is based on a PCM2707C chip. This chip supports PCM audio streams up to 16bit 48kHz. In addition to the I2S output, the module also provides an SPDIF output and a Jack 3.5mm output.
Reference : 16853
17,90 €tax incl.
14,92 € tax excl.
Digital Interface
Interface numérique USB vers I2S / SPDIF / Jack 3.5mm PCM2707C 16bit 48kHz
This affordable USB to I2S digital interface module is based on a PCM2707C chip. This chip supports PCM audio streams up to 16bit 48kHz. In addition to the I2S output, the module also provides an SPDIF output and a Jack 3.5mm output. The selection of the output is done with a switch on the module.
Output selection :
Pinout & Dimensions :
Product typeDigital interface
Input1x USB-B
OutputsI2S
SPDIF
1x Jack 3.5mm
Supported sampling ratesPCM up to 16bit 48kHz
Interface chipPCM2707C
CompatibilityWindows XP / 7 / 10
Android
iOS
Supply voltage5VDC via USB
Dimensions30 x 69mm
OutputI2S
OutputJack 3.5mm
OutputSPDIF
Max sampling rate48kHz
This affordable USB to I2S digital interface module is based on a PCM2707C chip. This chip supports PCM audio streams up to 16bit 48kHz. In...
