Digital Upsampling Interface SRC AK4137 I2S 32bit 384kHz DSD256 with Screen
This digital interface module integrates an AKM AK4137EQ chip supporting high sampling rates: PCM up to 32bit 384kHz, DSD up to DSD256 and DoP. This chip also allows PCM to DSD, DSD to PCM, DoP to PCM, DoP to PCM and DoP to DSD conversions.
Reference : 13770
34,90 €tax incl.
29,08 € tax excl.
Digital Interface
Digital Upsampling Interface AK4137 I2S 32bit 384kHz DSD256 with Screen
Interface Digitale Upsampling AK4137 I2S 32bit / 384kHz DSD256
This digital interface module integrates an AKM AK4137EQ chip supporting high sampling rates: PCM up to 32bit 384kHz, DSD up to DSD256 and DoP. This chip also allows PCM to DSD, DSD to PCM, DoP to PCM, DoP to PCM and DoP to DSD conversions. Input and output are in I2S on two 6-pin connectors and it is possible to select the I2S format (left or right justified). The AK4137EQ chip integrates a clock coupled to two other TXC clocks on the module, in order to considerably reduce jitter by allowing signal synchronization. This interface allows you to enjoy a high quality audio signal for rich and accurate sound reproduction.
4 buttons on the PCB allow you to control the input/output formats and modes, sampling rates and bit depths, digital filters and the activation/disactivation of the Dithering and Mute modes.
I2S/DSD input pinout
1Enabled DSD input (DSDON)
2GND
3DATA/DSD input
4BCK/DCLK input
5-
6LRCK/DSDR input
I2S/DSD output pinout
1Enabled DSD output (DSDON)
2GND
3DATA/DSD output
4BCK/DCLK output
5MCLK output
6LRCK/DSDR output
Diagram
Interface Digitale Upsampling AK4137 I2S 32bit / 384kHz DSD256 DoP
Interface operation
Select the input mode: It is first necessary to determine if the input signal is in DSD or PCM. The input mode can then be selected manually using the 2-pin D/P connector. By short-circuiting both contacts, the PCM mode is selected; otherwise, the DSD mode is active. The input mode can also be automatically controlled by pin 1 of the I2S/DSD input. For the DoP mode, simply choose the PCM mode.
If you use the automatic selection mode by connecting pin 1 of the I2S/DSD input, be careful not to connect the D/P connector.
Selecting the input format : In PCM mode, it is possible to modify the input format by making a long press on button 1 (B1). Depending on your input signal, you can select I2S formats, Left Justified (LJ), Right Justified 24bit (RJ24), Right Justified 32bit (RJ32), DoP. In DSD mode, the sampling rate can be modified by making a long press on button 2 (B2) among DSD64, DSD128, DSD256. The DSD sampling rate can also be automatically selected using the K1 and K2 pins by associating the module with an Amanero interface. Pin K1 must be connected to pin 18 of the Amanero module and pin K2 connected to pin 19 of the latter.
Mode DSDK1K2
DSD6400
DSD12801
DSD25610
Long press on button 2 (B2)11
In the previous table, 0 corresponds to a low level input (0V) and 1 to a high level input (3.3V).
Selecting the output format : The output format can be selected by making a short press on button 1 (B1). It is possible to select DSD64, DSD128, DSD256, Left Justified (LJ), I2S, Right Justified (RJ).
Setting the sampling rate for the PCM output mode: It is possible to select the output sampling rate in PCM mode by performing a short press button 2 (B2). It is possible to select 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176kHz, 192kHz, 352kHz, 384kHz and SLA (slave mode output).
Selecting the bit depth for the PCM output mode: To change the bit depth in PCM mode, simply make a short press button 3 (B3). The module offers a selection between 16bit, 20bit, 24bit and 32bit.
Digital filter selection: This module offers several digital filters to adapt the sound reproduction to your listening type and system. To change the digital filter, do a long press on button 3 (B3). The available filters are as follows:
DF1Sharp roll-off
DF2Slow roll-off
DF3Short delay sharp roll-off
DF4Short delay slow roll-off
Activation of dithering (DT) : The dithering mode can be activated by long pressing button 4 (B4). This reduces distortion by adding noise to the input signal, which is much less sensitive to the ear.
Mute mode (MT) : To activate / deactivate the mute mode, simply do a short press on button 4 (B4).
Product typeDigital interface
ChipAKM AK4137EQ
InputI2S / DSD 6 pins connector
OutputI2S / DSD 6 pins connector
ClocksTCX 24.576 + TCX 22.5792
Supported sampling ratePCM up to 32bit 384kHz
DSD up to  DSD256
Power supply5VDC via 2 pins connector (power supply sold separately)
Interface PCB dimensions63 x 52mm
Interface PCB fixation holes spacing57.5 x 47mm
Screen PCB dimensions80 x 36mm
Screen PCB fixation holes spacing75 x 31mm
Package1x Digital interface
1x Screen
Screen wiring
InputI2S
OutputI2S
Max sampling rate384kHz
Max sampling rateDSD256
Tested and works brilliant,
Also that`s a good piece inside a good plan to a realtime "re-master" of all digital inputs direcly to highest resolution and format.
This review has been posted for Digital Upsampling Interface SRC AK4137 I2S 32bit 384kHz DSD256 with Screen
This digital interface module integrates an AKM AK4137EQ chip supporting high sampling rates: PCM up to 32bit 384kHz, DSD up to DSD256 and DoP....
