IAN CANADA I2S to PCM Conversion Board
This I2S to PCM conversion module from Ian Canada has been developed to improve the sound performance of audio systems using a MULTIBIT digital to analog conversion chip.
Reference : 16964
105,00 €tax incl.
87,50 € tax excl.
Shipping date: 25-04-2025.
Ian Canada
I2S to PCM conversion board
Ian Canada Module de Conversion I2S vers PCM
Many people enjoy the sound of traditional MULTIBIT DACs, such as the AD1865/62, PCM170402, PCM63, TDA1541/A and many others. However, most of these MULTIBIT DACs were designed to work with digital filter chips through a PCM interface that transmits left and right data simultaneously. In this case, the problem is that the sound quality and maximum sampling rate (Fs) of these DACs may be limited by the performance of the oversampling digital filter chip, due to low computational accuracy, the interpolation algorithm and old technologies delivering high jitter.
To improve the sound quality by using better jitter reduction technology and to allow the playback of higher sample rates, it is necessary to get rid of the limitation of the digital filter chip by driving the MULTIBIT DAC from a high performance oversampling filter or by directly streaming a high sample rate audio stream. It is therefore necessary to use an optimized jitter system to control the MULTIBIT DAC in NOS mode from an I2S bus.
This I2S to PCM module from Ian Canada has been developed with exactly this in mind to improve the sound performance of these audio systems.
Key features :
  • Support PCM 16/18/20/24bit outputs.
  • Accepts I2S input signals from 16 to 32bit with SCK from 32*Fs to 64*Fs.
  • Pure NOS mode with bit-perfect format conversion.
  • High speed design with support for sample rates up to 384kHz (Fs) and a maximum MCLK of 100MHz.
  • Supports PCM63, AD1865, AD1862, PCM1704, PCM1702, TDA1541/A and many other MULTIBIT DACs.
  • Supports the operation of the TDA1541/A in offset binary mode.
  • Full and half speed mode selectable via jumper.
  • Simultaneous L/R synchronization, starting the digital/analog conversion on the same locking edge to eliminate the L/R phase difference.
  • In order to reduce the background noise of the DAC the clock can be stopped after shifting the data into the DAC (default).
  • Supports dual-monoc DAC configurations.
  • Logical synchronization architecture optimized for jitter.
InputPCB Connector
OutputPCB Connector
Max sampling rate384kHz
Interface chipNC
be careful!
There wasn't any power cable in my set,but photo shows the power cable?
Also be careful about TP1 AND TP9 through holes,because silk white writing indicates dc and gnd are wrong! It is almost like a trap! Small mistake but audiophonics should write a note under this product about it!
Maybe he should add uf.l connectors into this set..
For me,uf.l pads should be on front side of the pcb(hear me Ian :)
Connectors are well aligned,I liked the pcb quality,I didn't test yet,but I powered the board without any problem.
Thanks!
This review has been posted for IAN CANADA I2S to PCM Conversion Board
This I2S to PCM conversion module from Ian Canada has been developed to improve the sound performance of audio systems using a MULTIBIT digital to...
