IAN CANADA TRANSPORTPI AES Ultra-Low Jitter AES/EBU SPDIF Digital Interface Module
Ian Canada's TransportPi AES is an AES/EBU and SPDIF digital interface board. It is the first model to use a 1bit 50Mbps differential driver and a dedicated femtosecond clock to achieve the highest possible signal quality and very low noise for both AES/EBU and SPDIF outputs.
Reference : 17544
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 29-04-2025.
Ian Canada TransportPi AES
Ian Canada TransportPi AES Interface numérique SPDIF AES/EBU ultra-faible jitter
Ian Canada's TransportPi AES is an AES/EBU and SPDIF digital interface board. It is the first model to use a 1bit 50Mbps differential driver and a dedicated femtosecond clock to achieve the highest possible signal quality and very low noise for both AES/EBU and SPDIF outputs. The module also incorporates an excellent 1bit discrete reclocker, similar to the ReClockPi, to provide extremely low jitter. The TransportPi AES is thus positioned as a true flagship in the field of audiophile AES/EBU and SPDIF interfaces, allowing a significant improvement in the sound quality of an external DAC.
Key features :
  • High-end AES/EBU and SPDIF interface module with isolated AES/EBU, coaxial and Toslink optical outputs (BNC output not isolated).
  • 1bit 50Mbps discrete differential driver to achieve the best possible AES/EBU signal quality with very low noise.
  • Dedicated femtosecond clock for SPDIF outputs to achieve the best possible signal quality and extremely low jitter.
  • Integrated 3-stage 1bit discrete secondary reclockers.
  • Improved high bandwidth power supply filtering networks.
  • LDO-free architecture for direct use of a 3.3V supercapacitor or battery power supply to get the best power supply performance.
  • Optimized PCB impedance control for high speed AES/EBU and SPDIF signals
  • 4-layer PCB with dedicated shielding layer to eliminate EMI noise.
  • Ultra-low noise metal film resistors to ensure the lowest possible noise level.
  • Support of AES/EBU and SPDIF streams up to 192kHz. Possibility to support 384kHz with qualified receiver.
  • Interchangeable and upgradeable AES/EBU and SPDIF transformers
  • Support for MCLK frequencies from 5.6448MHz to 98.304MHz.
  • Support of I2S and DoP formats in input.
The TransportPi AES operates in synchronous clock mode. It requires the addition of a FifiPiMa, FifoPiQ7 or FifoPiQ3 add-on module (sold separately) to operate.
Product typeDigital interface board
InputGPIO
Outputs1* Coaxial
1* Optical Toslink
1* BNC
1* AES/EBU
1* GPIO
Other connectors1* External MCLK clock input
Supported sampling ratesMax. 384kHz
Supported input formatsI2S
DoP
Input impedanceAES/EBU : 110Ω
Coaxial : 75Ω
BNC : 78Ω
Output levelAES/EBU : 3Vp-p (single-ended) / 6Vp-p (balanced)
Coaxial : 0.8Vp-p
BNC : 0.8Vp-p
InputGPIO
OutputAES/EBU
OutputCoaxial SPDIF
OutputGPIO
OutputOptical Toslink
OutputBNC
Max sampling rate384kHz
Interface chipNC
Excellent system
I now have a very detailed and rich sounding streamer with a huge sound stage built with this and other Ian Canada boards. I have provided a more detailed and informative review on the Ian Canada PurePi II that will help you if you are considering building your own streamer.
This review has been posted for IAN CANADA TRANSPORTPI AES Ultra-Low Jitter AES/EBU SPDIF Digital Interface Module
Ian Canada's TransportPi AES is an AES/EBU and SPDIF digital interface board. It is the first model to use a 1bit 50Mbps differential driver...
