Interface Extractor Module HDMI to HDMI I2S / SPDIF
This interface module allows you to extract and split the signal from the HDMI input. This can then be output in HDMI, I2S or S/PDIF.
Reference : 14216
19,90 €tax incl.
16,58 € tax excl.
HDMI Interface
Module Interface Extracteur HDMI vers HDMI / I2S / SPDIF
This interface module allows you to extract and split the signal from the HDMI input. This can then be output in HDMI, I2S or S/PDIF. HDMI input and output is done on mounted connectors. The I2S and S/PDIF outputs are to be wired to the contact points provided for this purpose. HDMI input and output support video streams up to 2K.
Product typeHDMI Interface
Input1x HDMI
Outputs1x HDMI
1x I2S
1x S/PDIF
Max. supported HDMI video resolution2K
Power supply5V DC (power supply sold separately)
Dimensions70 x 70mm
Fixation holes spacing63 x 42mm
InputHDMI
OutputI2S
OutputHDMI
OutputS/PDIF
