LHY AUDIO DIR9001Interface Module SPDIF to I2S 24bit 96kHz
This SPDIF to I2S interface module allows to get a signal from a coaxial or optical Toslink input for output to I2S. It uses a Burr Brown DIR9001 receiver chip and supports PCM streams up to 24bit 96kHz.
Reference : 17274
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 16-04-2025.
LHY Audio DIR9001 Interface Module
Module interface SPDIF vers I2S DIR9001 24bit 96kHz
This SPDIF to I2S interface module allows to get a signal from a coaxial or optical Toslink input for output to I2S. It uses a Burr Brown DIR9001 receiver chip and supports PCM streams up to 24bit 96kHz. The clock rate of the module can be adjusted to 128, 256, 384 or 512fs and the I2S format can be changed with two switches.
Product typeSPDIF to I2S module interface
Inputs1* Optical Toslink
1* Coaxial
Output1* I2S (to solder)
Supported sampling ratesPCM up to 24bit 96kHz
Supply voltage5VDC
Total dimensions (L*P*H)64*57.3*14.5mm
Mounting holes spacing56*25mm
OutputI2S
Max sampling rate96kHz
Interface chipDIR9001
The product is as described.
Fast delivery from France to Germany.
This review has been posted for LHY AUDIO DIR9001Interface Module SPDIF to I2S 24bit 96kHz
This SPDIF to I2S interface module allows to get a signal from a coaxial or optical Toslink input for output to I2S. It uses a Burr Brown DIR9001...
