MiniDSP miniSTREAMER USB to SPDIF / I2S Interface 24bit 96kHz
Reference : 9847
42,90 €tax incl.
35,75 € tax excl.
The miniSTREAMER is a versatile and compact 24bit 96kHz USB to SPDIF and I2S interface that fits a wide range of DIY applications.
On a PCB of only 37x60mm, this interface is the ideal solution for the high performance applications dedicated to digital audio processing.
The miniSTREAMER uses a USB 2.0 port to provide simultaneous playback and digital recording.
Plug & Play, the interface requires no driver for both Mac and Windows platforms.
The easy and flexible integration of the system follows the traces of the miniDSP product line.
The miniSTREAMER is an innovative audio interface for a wide range of DIY applications.
Characteristics :
  • TENOR TE7022L Adaptive USB interface
  • USB 2.0 port
  • RCA coaxial input SPDIF
  • Digital outputs: RCA Coaxial SPDIF and I2S (IC format)
  • Reading and recording at 24bit 96kHz natively
  • Native support 24bit 96kHz
  • Signal I2S amplified by Buffer
  • Dynamic range: 133dB
  • Dimensions: 84x37x12mm
  • Compatible with Mac OS X, Windows XP, Vista, 7, 8
  • USB cable 1m and M3 x2 screws supplied
An excellent device, at a good price, promptly delivered
The unit was shipped promptly and arrived in just a short time, despite the fact that I am in the UK. The unit itself is very compact and it would in fact be useful if the suppliers recommended a specific box to suit it. I am using the unit on a Macintosh system where it is used to send signals out to outboard digital signal processing and mixing and then bring them back for internet broadcasting. The unit does this job simply and easily and at high quality. I note that the bit specifications must be the same at input and output (eg 16-bit 44.1kHz: it is simply configured with Audio MIDI Setup on the Mac) - I would have liked to send 24-bit and receive 16 after external dithering - however this is not an audible issue. Overall an excellent product at an affordable price.
This review has been posted for MiniDSP miniSTREAMER USB to SPDIF / I2S Interface 24bit 96kHz
