RJ45 Balanced I2S Input to Asymetrical I2S Output Module Board
Reference : 11386
24,90 €tax incl.
20,75 € tax excl.
This input module allows you to integrate a balanced RJ45 to I2S input to the audio device of your choice. Ideal for any type of project and DIY assembly. This module uses the symmetric buffer AM26L32.
The main interest of a symmetrical signal makes it possible to lower the noise over long lengths to carry an audio I2S signal. It works in concert with the module 11387 I2S Unbalanced to RJ45 Symmetric .
It is thus possible to use an RJ45 type cable of a length of 1 m and more in place of the usual 20 cm of the I2S signal.
Attention: For RJ45 I2S connections the connections must be as short as possible.
Features:/ Strong>
  • Input Module: RJ45 to I2S Symmetric
  • Chips: AM26LS32DC
  • ELNA electrolytic capacitor
  • Connector SMA (Female)
  • Dimensions: 43,6 x 41mm
  • Mounting brackets: 33 x 30mm
  • Weight: 20g
  • Voltage Rating: 7-12V DC
Cable schematics :
Schéma de câblage - Input
InputI2S via RJ45
OutputI2S
Max sampling rateNC
Interface chipAM26L32
