SUPTRONICS X10-I2S USB XMOS Interface to I2S / Opical / Coaxial SPDIF 32bit 384kHz DSD
This X10-I2S module will allow you to enjoy a USB interface to I2S, Coaxial and Optics in a very simple way. So you can upgrade your DIY audio system based, for example, on a Raspberry Pi and offer it new possibilities.
Reference : 12834
59,90 €tax incl.
49,92 € tax excl.
SUPTRONICS I2S-X10 V2
BRAVO SA9227 Interface to I2S / Coaxial SPDIF / Optical 32bit 384kHz DSD
The X10-I2S module allows it user to enjoy a USB interface to I2S, Coaxial and Optical in a very simple way. It is very useful when it comes to upgrade any DIY audio system based for example on a Raspberry Pi to provide new possibilities.
List of modules of the X10 and X20 series sold separately:
USB chip SA9227
This USB interface is based on a chip BRAVO Audio SA9227. This component has excellent audio capabilities and can handle seamlessly digital audio streams up to 384kHz 16/24/32 bit (PCM). The 1-bit formats are not left behind with a DSD64 / DSD 128 support.
A fully autonomous interface
The SA9227 interface is first designed to be used directly with a SBC Raspberry Pi.
It can also operate in standalone mode, a solution that allows changing the DAC Module quickly and effortlessly for benchmarking hardware or to favor a specific speaker / amp technology when listenning.
This solution is therefore as good as practical and economical.
Connectors
This interface offers your system a more complete connectivity. Thus, as input we will find a USB-A 2.0 port supported by an SA9297 chip. The interface also comes with a small USB loopback extension, making it easy to connect this X10-I2S to another module.
Caution : the port layout on a Raspberry Pi 4 does not fit with this extension. Use a USB-A to USB-A male cable instead.
On the output side, the module offers SPDIF (Coaxial), Toslink Optics and I2S for optimal sound quality.
Components
The interface also incorporates an ultra-low phase jitter SiTime SiT8208 SiTime oscillator, a Pulse PE-6561NL digital signal transformer with a design to limit EMI noise and interference, and an ultra-low noise voltage regulator from Texas Instruments for optimal operation.
USB interfaceXMOS
Sampling rates supportedUSB : PCM up to 32bit 384kHz / up to DSD128 Native
SPDIF : PCM up to 24bit 192kHz
Supported OSVolumio, Moode Audio PLayer, Windows, Android...
OscillatorSiTime SiT8208
Digital signal transformerPulse PE-6561NL
Voltage RegulatorTexas Instruments Ultra-Low Noise Voltage Regulator
DSDNative, DoP64, DoP128
Power supply5V DC ±5%
Dimensions85 x 56 x 15mm
Fixation holes distances58 x 49mm
AccessoriesUSB extension board
Screws and spacers
The announced sampling rates are only valid on the I2S output. They are therefore not valid for use with an X10-DAC / X20-DAC. With the latter, the sampling rates in PCM go up to 24bit 192kHz.
Use X10-I2S interface with Volumio
The X10-I2S interface is compatible with Volumio. To be able to use these two solutions together, a simple manipulation is necessary.
  • In the Volumio interface, go to the Playback Options menu.
  • Disable I2S DAC option.
  • In the Output Device field, select xCORE-AUDIO Hi-Res 2.
  • Reboot Volumio.
Interface X10-I2S avec Volumio
OutputI2S
OutputCoaxial SPDIF
OutputOptical Toslink
This X10-I2S module will allow you to enjoy a USB interface to I2S, Coaxial and Optics in a very simple way. So you can upgrade your DIY audio...
