TINYSINE SPDIFBee Interface Module SPDIF to I2S DIR9001+CS8421 24bit 96kHz
This Tinysine SPDIFBee interface module converts an SPDIF signal via a coaxial input into an I2S signal. A DIR9001PW chip converts the SPDIF signal to I2S, while the CS8421 chip handles the sampling rate.
Reference : 18172
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 22-04-2025.
TINYSINE SPDIFBee
This Tinysine SPDIFBee interface module converts an SPDIF signal via a coaxial input into an I2S signal. A DIR9001PW Burr-Brown chip converts the SPDIF signal to I2S, while the Cirrus Logic CS8421 chip handles the sampling rate. This module is capable of receiving sampling rates ranging from 16bit 44.1kHz to 24bit 96kHz, before converting it into a 16bit 48kHz I2S signal. The I2S output is on 2mm PCB connectors.
Product typeInterface module SPDIF to I2S
Interface chipsDIR9001+CS8421
InputSPDIF Coaxiale
OutputPCB connectors (2mm)
Supported sample ratesPCM 24bit 96kHz
Taux d'échantillonnage I2S16bit 48kHz
Input voltage5V DC
Dimensions40 x 35x 20mm
Package1x Interface module Tinysine SPDIFBee
OutputPCB Connector
Max sampling rate96kHz
Interface chipCS8421
Interface chipDIR9001
This Tinysine SPDIFBee interface module converts an SPDIF signal via a coaxial input into an I2S...
