TINYSINE TOSLINKBEE Interface Module SPDIF Optical to I2S DIR9001 CS8421 24bit 96kHz
This Tinysine ToslinkBee interface module converts an SPDIF signal via an optical Toslink input into an I2S signal. A DIR9001PW Burr-Brown chip converts the SPDIF signal to I2S, while the Cirrus Logic CS8421 chip handles the sampling rate.
Reference : 18397
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 22-04-2025.
TINYSINE ToslinkBee
Interface Module SPDIF Optical to I2S DIR9001+CS8421 24bit 96kHz
TINYSINE ToslinkBee Interface Module SPDIF Toslink to I2S DIR9001+CS8421 24bit 96kHz
This Tinysine ToslinkBee interface module converts an SPDIF signal via an optical Toslink input into an I2S signal. A DIR9001PW Burr-Brown chip converts the SPDIF signal to I2S, while the Cirrus Logic CS8421 chip handles the sampling rate. This module is capable of receiving sampling rates ranging from 16bit 44.1kHz to 24bit 96kHz, before converting it into a 16bit 48kHz I2S signal. The I2S output is on 2mm PCB connectors.
TINYSINE ToslinkBee Interface Module SPDIF Optical to I2S DIR9001+CS8421 24bit 96kHz
Product typeInterface module SPDIF to I2S
Interface chipsDIR9001+CS8421
InputSPDIF Optical Toslink
OutputPCB connectors (2mm)
Supported sample ratesPCM 24bit 96kHz
Taux d'échantillonnage I2S16bit 48kHz
Input voltage5V DC
Dimensions40 x 35x 20mm
Package1x Interface module Tinysine TOSLINKBee
OutputPCB Connector
Max sampling rate96kHz
Interface chipCS8421
Interface chipDIR9001
This Tinysine ToslinkBee interface module converts an SPDIF signal via an optical Toslink input into an I2S signal. A DIR9001PW Burr-Brown chip...
