ADUM3160 USB 2.0 Isolator 12Mbps 1x USB-B to 4x USB-A Module
This plug and play USB 2.0 isolator module lets you enjoy a cleaner signal on a wide range of devices thanks to its four USB-A outputs. This USB isolator supports data transfers from 1.5 Mbps to 12 Mbps.
Reference : 17895
16,90 €tax incl.
14,08 € tax excl.
USB 2.0 Isolator Module
USB 2.0 Isolator 12Mbps 1 USB-A to 4 USB-A
This Plug & Play USB 2.0 isolator module lets you enjoy a cleaner signal on a wide range of devices thanks to its four USB-A outputs. It incorporates an ADuM3160 digital isolator, a USB hub chip and can be powered from either the USB-B input or an external 5V DC power supply (sold separately). Each USB port on this module has a dedicated ESD protection chip. This USB isolator supports data transfers from 1.5Mbps to 12Mbps.
The output power of the B0505S is 1x2W. When the total operating current of the USB device exceeds 400mA, the DC5V external power supply is required.
Isolateur USB 2.0 12Mbps 1 USB-A vers 4 USB-A
1USB-A input
2USB ADuM3160 isolator
3USB Hub
4ESD protections
5B0505S
65V DC external power supply interface
74x USB indicators
84x USB-A output
Product typeUSB isolator module ADUM3160
Input1x USB-B
Ouputs4x USB-A
USB compatibility2.0
Bandwidth1.5Mbps to 12Mbps
ADuM3160 chip isolation voltage2500V
Power supply module isolation voltage1500V
Power supply voltage5V DC
Dimensions70*38mm
Weight30g
OutputUSB
Max sampling rateNC
Interface chipADUM3160
This plug and play USB 2.0 isolator module lets you enjoy a cleaner signal on a wide range of devices thanks to its four USB-A outputs. ...
