WONDOM AA-AB41164 ADC Module
This WONDOM AA-AB41164 ADC module is based on a Texas Instrument Burr-Brown PCM1822 chip, enabling it to process two analog signal channels simultaneously. It can convert both unbalanced stereo analog signals and balanced stereo analog signals into I2S signals. This ADC module supports sampling rates up to PCM 24bit 192kHz.
Reference : 19400
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 24-04-2025.
Wondom AA-AB41164 Stereo ADC Board PCM1822 I2S 24bit 192kHz
WONDOM AA-AB41164 module picture
This Wondom AA-AB41164 ADC module is based on a Texas Instruments Burr-Brown PCM1822 chip, enabling it to process two analog signal channels simultaneously. It can convert both single-ended stereo analog signals and balanced stereo analog signals into I2S signals. This ADC module supports sampling rates up to PCM 24bit 192kHz. It can be used in master or slave mode, depending on the application. Several operating modes are configurable via 4 selector switches. The entire module can be supplied with 6-24V DC via a micro-fit connector, or via a Wondom BCPB series battery module. All in all, the WONDOM AA-AB41164 ADC module boasts very good measurements and a good level of performance:
  • 0.00047% THD+N
  • Low output noise at 0.97uVrms
  • SNR up to 119dB
  • Dynamic range up to 111dB
  • High level of flexibility thanks to various operating modes
  • 3-wire I2S output for signal protection against EMI/RFI interference
Wondom AA-AB41164 ADC module overview
WONDOM AA-AB41164 ADC module overview
1Power connector for 6-24V DC battery (Wondom BCPB)
2MicroFit 6-24V DC power connector
3Balanced left channel input
4Single-ended stereo signal input
5Balanced right channel input
6I2S output
7Input selector (Balanced / Single-ended)
8Dip switch for operating mode selection
WONDOM AA-AB41164: Output and input mode selection
Operating modes of the WONDOM AA-AB41164 module
Note that "LOW" mode is always selected by turning the switch upwards, and downwards for "HIGH" mode.
Dimensions of the WONDOM AA-AB41164 module
Product typeADC board
ADC chipBurr-Brown TI PCM1822
Inputs1x Single-ended stereo signal input
1x Balanced stereo signal input
OuputI2S
Supported sample ratesPCM up to 24bit 192kHz
AUdio Performances
ParametersConditionsMin.Typ.Max.
Frequency responseVin=100Vrms (VCC=12V)0.02kHz-20kHz
GainBalanced and unbalanced--0.31dB-
Input sensitivityBalanced and unbalanced-0.1mV-
Bandwidth @ +/-3dB-20Hz-20kHz
THD+NVCC=12V
Niveau=100mVrms (A-wt)
-0.00047%-
Output noise levelInput connected to GND (A-wt)-0.97uVrms-
SNRVCC=12V
Level=100mVrms (A-wt)
-119.93dB-
ELectrical SPecifications
Frequency responseVoltage DC power supply6V DC12V DC24V DC
Sample rates-8kHz48/96kHz192kHz
Rated currentVCC=12V0.08A0.12A0.3A
Idle powerVCC=12V1.35W1.5W1.65W
Output I2S parameter24bit 44.1-48/96kHz-48kHz-
Input impedanceBalanced and unbalanced-2.5kΩ-
Operating temperatureOperating ambient temperature-20°C25°C65°C
GEnEral
Dimensions76.2 x 50.8 x 12mm
Package1x Wondom ADC module AA-AB41164
1x JST PH-5 line input cable to 3.5mm female jack input
1x Microfit-2 power cable to bare wires
WONDOM AA-AB41164 board measurements
InputPCB Connector
InputJack 3.5mm
OutputI2S
DAC / ADC ChipPCM1822
Max sampling rate192kHz
Interface chipNC
WONDOM AA-AB41164 Stereo ADC Module PCM1822 I2S 24bit 192kHz
This WONDOM AA-AB41164 ADC module is based on a Texas Instrument Burr-Brown PCM1822 chip, enabling it to process two analog signal channels...
