In-Ear Monitor IEM Planar Magnetic
The IEM Audeze iSine 10 headphones offer unparalleled sound quality and design, featuring an innovative design based on Planar Magnetic speakers. The Fluxor™ magnets and the large 30mm diaphragms ensure exceptional precision and dynamics, without distortion, to bring your music to life. Add to that the Lightning cable with its DSP and no other IEM is able to approach the performance of the iSine 10.
Miniaturizing Planar Magnetic speakers is not an easy task. The new iSine range offers headphones weighing only 20 grams and incorporating all the exclusive and patented Audeze technologies, including the Fluxor™ magnets, allowing the magnetic drive force of the large and ultra thin diaphragms to be almost doubled, incorporating the patented Uniforce™ coil technology for an absolutely exceptional precision experience. The distortion (THD) is thus less than 0.1%, even at high volume. An incredible achievement for in-ear headphones!
Lightning CIPHER Cable: The Audeze CIPHER 24bit cable includes a high quality amplifier, DAC, microphone with Siri compatibility and a DSP that can be customized via application. Useful and powerful features to maximize the sound quality of iSine 10.
Bluetooth CIPHER Module: The Audeze CIPHER Bluetooth module is a detachable and lightweight device that allows the iSine headphones to be transformed into a Bluetooth headset with built-in microphone and volume control. The module also supports aptX and aptX HD, allowing 24-bit audio resolution playback with low latency and fully transparent compatibility with the latest Bluetooth devices
Audeze HQ App: Download the free Audeze HQ iOS application for use with the CIPHER Lightning cable and create up to 2 sound profiles via a 10-band graphic equalizer.
To bring the sound quality of their award-winning LCD range to the iSine 10, Audeze worked closely with their strategic partner Designworks, a subsidiary of the BMW Group. Each part of the iSine is designed to deliver the world-renowned Audeze sound to a wider market in a compact and lightweight format. Particular care has been taken with the iSine range, starting with the hull, which reduces reflections and diffractions for perfect listening comfort. In addition, with only 20 grams on the scale, these iSine 10 are currently the lightest Planar Magnetic headphones / headphones ever designed!
" Not only did the iSINE headphones sound markedly better than any closed in-ear models I’ve tried (several dozen, for the record), but they are also one of the few that come with a cord compatible with the iPhone7. "
" The iSine 10 are a fantastic buy, and a worthy addition (or start!) to your high-end headphone collection. "
" Audeze, which makes some of the greatest headphones in the world, has perfected the planar design like no other brand. "
" The Audeze iSine10 is this world’s first in-ear planar magnetic headphone and it’s impressive from the sturdy feel to the sound they push out. It’s a game changing experience worth the money. "
" They’re remarkably clear and crisp ... like looking through a window that you’ve just wiped clean for the first time. "
Specifications | ||
Product type | In-Ear Monitors | |
IEM Type | Semi-open | |
Transducer type | Planar Magnetic | |
Magnetic structure | Fluxor™ magnet array | |
Phase management | FAZOR | |
Magnet type | Neodymium N50 | |
Diaphragm type | Ultra-thin Uniforce™ | |
Transducer size | 30mm | |
Maximum supported power | 500mW RMS | |
Maximum SPL | > 130dB | |
Frequency response | 10Hz - 50kHz | |
THD | < 0.1% @ 100dB | |
Impedance | 16Ω | |
Sensitivity | 110dB/1mW | |
Power requirement | > 50mW | |
Package | 1x Audeze iSine 10 1x Stereo Jack 3.5mm to 2 pins connector cable 1.5m 1x Lightning to 2 pins connector cable 1.5m |
