FIIO FD3 PRO In-Ear Monitors IEM Dynamic Drivers DLC Diaphragm 32 Ohm 10Hz-40kHz 111dB
FiiO's FD3 Pro are in-ear monitors (IEMs) featuring exceptional design quality, including dynamic 12mm drivers with DLC (Diamond Like Carbon) cone in a semi-open design. They offer a magnificent quality of sound reproduction, rich and precise, capable of revealing the smallest details of your music.
Reference : 15671
175,00 €tax incl.
145,83 € tax excl.
FiiO FD3 Pro
FiiO FD3 Pro Écouteurs Intra-Auriculaires IEM Haut-Parleurs Dynamiques Membrane DLC 32 Ohm 10Hz-40kHz 111dB
A new challenger has arrived
The FD3 Pro follows in the footsteps of the other models in the FD series by using a new 12mm dynamic driver. Inside the FD3 Pro's shell is a large magnet driver with a magnetic flux of 1.5 Tesla, combined with an ultra-thin Japanese Daikoku copper-plated aluminum coil, for a powerful sound.
Carbon DLC diaphragm
The FD3 Pro benefits from the many advantages of the new FiiO dynamic driver. The cone is made of Diamond Like Carbon (DLC), which is both extremely rigid, helping to reduce unwanted distortion, and incredibly light, allowing for excellent transient response. The result is a speaker with excellent sound quality, minimal distortion and high sensitivity.
High-end acoustic prism
The acoustic prism already used in the FD5 is also integrated in the FD3. It offers many advantages, eliminating high frequency static waves, improving the diffusion of sound waves and effectively solving the delay problem caused by the propagation of sound waves in the cavity. This design results in exceptional sound quality and purity.
Semi-open design
The semi-open design of the FD3 Pro, based on FiiO's patented air pressure technology, offers several advantages. Not only does it allow for a more natural sound, but it also effectively protects your hearing by balancing the air pressure in the earphones to limit the pressure on your eardrums. This makes for much less tiring listening.
Design & Performances
The FD3 Pro has a simple and elegant aesthetic based on the use of curves. The unique celluloid panel is covered with a 2.5D glass film offering a transparent design. The Aluminum and Magnesium alloy also allows the FD3 Pro to remain extremely light and comfortable.
In search of perfection
Fiio has always wanted to offer products with good design quality. The FD3 Pro is no exception. The Aluminum-Magnesium headphone body is precisely machined using a 5-axis CNC and polished by hand. The precision of the machines and the finesse of the craftsmanship combine to offer a piece of very high quality.
A tailor-made restitution
The sound tubes that were particularly well received on the FD5 are back on the FD3 Pro. While the outer diameter of these tubes is still the same, each model has its own inner diameter. Thus, the model with a larger inner diameter (black) will offer detailed highs, while the one with a smaller inner diameter (red) will develop deep bass. It is thus very easy to adapt the sound of the FD3 Pro to one's listening and desires.
Optimized in every detail
The attention to detail has been pushed to the design of the cable of these IEM. Detachable, it adopts MMCX connectors. The conductors, braided and 8 in number, are made of high purity monocrystalline copper and silver plated. Each conductor is made of 19 strands, for a total of 152 strands braided together to form Litz Type 2 wires. In addition, the cable features an interchangeable connector, allowing you to use either a 2.5mm jack, 3.5mm jack or 4.4mm jack, depending on your source.
A particularly complete set of accessories
The FD3 Pro comes with many accessories to facilitate and enhance your experience with these headphones. They come with 3 pairs of balanced sound tips (S, M, L), 3 pairs of bass tips (S, M, L), 3 pairs of vocal tips (S, M, L), 2 pairs of memory foam tips, a cleaning brush, a carrying case, a pair of extra sound tubes, a 3.5mm jack connector, a 2.5mm jack connector and a 4.4mm jack connector.
Product typeIn-Ear Monitors (IEM)
Drivers typeDynamic 12mm
Carbon DLC (Diamond Like Carbon) diaphragm
Body materialAluminum
Magnesium
CableDetachable
1.2m
Cable connectors2x MMCX
1x Jack 3.5mm
Cable conductorsSilver plated monocrystalline copper, 152 brins
Frequency response10Hz - 40kHz
Impedance32Ω @ 1kHz
Sensitivity111dB @ 1mW
Power handling100mW
Weight / IEM7g
Package1x FiiO FD3 Pro
1x MMCX mounting clip
1x Jack 2.5mm connector
1x Jack 3.5mm connector
1x Jack 4.4mm connector
3x Pairs of bass type tips (S, M, L)
3x Pairs of balanced type tips (S, M, L)
3x Pairs of voice type tips (S, M, L)
2x Pairs of memory foam tips
1x Cleaning brush
1x Carrying case
1x Pair of interchangeable sound tubes
Impedance (Ω)32
Efficiency / Sensitivity (dB)111
Lowest frequency (Hz)10
Highest frequency (Hz)40
FiiO's FD3 Pro are in-ear monitors (IEMs) featuring exceptional design quality, including dynamic 12mm drivers with DLC (Diamond Like Carbon)...
