AECO AT3-1351G Jack 3.5mm TRS Connector Tellurium Copper Gold Plated Ø6.5mm
The aeco AT3-1351G is a high-quality Jack 3.5mm TRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high purity tellurium copper with 10µ gold plating, ensuring excellent conductivity and limiting signal loss.
Reference : 18059
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 22-04-2025.
aeco AT3-1351G
aeco AT3-1351G Jack 3.5mm TRS Connector Tellurium Copper Gold Plated Ø6.5mm
The aeco AT3-1351G is a high-quality Jack 3.5mm TRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high purity tellurium copper with 10µ gold plating, ensuring excellent conductivity and limiting signal loss. The stainless steel body is insulated from the contacts by a nylon section.
Product typeMale Jack 3.5mm TRS connector
Contacts materialTellurium copper (purity: > 99%)
Contacts platingGold 10µ
Insulation materialNylon
Shell materialStainless steel
Max cable diameterWith reducer: Ø4.5mm
Without reducer: Ø6.5mm
Contacts resistance< 1mΩ
ColorSilver
Total dimensionsØ8.9*42.3mm
Max cable diameter (mm)6.5
Mounting typeTo weld
ConnecticMale
Contacts number3
The aeco AT3-1351G is a high-quality Jack 3.5mm TRS connector, designed using high-performance components for optimum transmission of the audio...
