AECO AT3-1351R Jack 3.5mm TRS Connector Tellurium Copper Rhodium Plated Ø6.5mm
The aeco AT3-1351R is a high-quality Jack 3.5mm TRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high purity tellurium copper with rhodium plating, ensuring excellent conductivity and limiting signal loss while protection it from oxidation.
Reference : 18060
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 29-04-2025.
aeco AT3-1351R
aeco AT3-1351R Jack 3.5mm TRS Connector Tellurium Copper Rhodium Plated Ø6.5mm
The aeco AT3-1351R is a high-quality Jack 3.5mm TRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high purity tellurium copper with rhodium plating, ensuring excellent conductivity and limiting signal loss while protection it from oxidation. The stainless steel body is insulated from the contacts by a nylon section.
Product typeMale Jack 3.5mm TRS connector
Contacts materialTellurium copper (purity: > 99%)
Contacts platingRhodium
Insulation materialNylon
Shell materialStainless steel
Max cable diameterWith reducer: Ø4.5mm
Without reducer: Ø6.5mm
Contacts resistance< 1mΩ
ColorSilver
Total dimensionsØ8.9*42.3mm
Max cable diameter (mm)6.5
Mounting typeTo weld
ConnecticMale
Contacts number3
The aeco AT3-1351R is a high-quality Jack 3.5mm TRS connector, designed using high-performance components for optimum transmission of the audio...
